mexanico1971 (31st March, 2013)
This file to repair hardware device
Whether to repair the program (software) will be working?
Thanl you boost, for uploading it again, but the file is also not working for me. WinRAR and Winzip says that file is damaged (file size with 2.62MB is OK)...
Can you or someone else upload it with winRAR compressed please ?
Best Regrds,
Eddi
Thanks bo0st, for to share this files!!!
I see some have unzip problems with this file. There appears to be a corrupt file within the folder perhaps this is the problem. Please see the image below. Perhaps you could tell us what "new file~" is? Cheers.
maybe this is the problem. can you upload it new packed without the bad file ?
BR
Eddi
samyy (25th August, 2017)
Thank you boost, now i can open it.
Do you maybe have a link to v55 for flashing ?
BR
Eddi
CLIP V85.txt
here can clip V85 good luck
I have a question for you
First, thanks for your post ;-)
I have a clone clip and i have use it one month but last time it isn't reconise on clip software... >> ISO GREEN/RED is off
I have search LT1766 and find it on "2.JPG" PCB or POWER DIODE LINE is on "1.JPG" PCB it's correctly ?
But on pin 10 I have 5.11V ....
Have you an over idea ?
Best regard Alain
