Page 42 of 45 FirstFirst ... 32373839404142434445 LastLast
Results 616 to 630 of 674
  1. #616
    ecumix's Avatar
    Apr 2014
    ok thanks for answer
  2. #617
    Harrycz44
    Guest
    Hi all have anyboda solution for peripherall disconecting ( Alliance with Bluetooth )??
  3. #618
    Jan 2013
    italy
    if exists, until today I haven't found one, so if you can send it back to the seller asap.
  4. #619
    Member JareckiPL's Avatar
    Dec 2013
    China sallers not going to fix it, do not waste your time. I also have same thing with two clips, disconnecting time to time. PCB is the same like Consult 3. My friend got the same clip with the same board and no problem with disconnecting.
  5. #620
    Jan 2013
    italy
    I was lurking the l04a's datasheets and I think that I saw something like 16V Vmax input. did somebody already tried to put a 7815 on the Vin as safeguard for those ocasions like starting the engine with clip attached?
  6. #621
    Dec 2013
    That`s no software problem and drivers for sure. You can connect just power supply, and usb to PC (without software runing). Any way if no action is taken after about 20 minuts green led blinking and bluetooth starts.
    You don`t have to be connected to the car to get disconnet for a moment.
    Some fixes: http://obd2-diag.blogspot.com/p/renault-can-clip.html
  7. #622
    Jun 2017
    Greetings!
    I have a SP19-B copy and everything is fine with it except one thing: it keeps disconnecting and reconnecting randomly. The first thing I wanted to do is the DPF regeneration on a Laguna ph2 but as it disconnected and reconnected, the Clip did not provide live datas anymore. Moreover, the DPF regeneration program did not end even after 1 hours. I use it with V164 Clip and also tried the 130 version with no luck .
    So the question is: Why does it disconnect?
    I hope you can help me
  8. #623
    Dec 2009
    thanks to all for sharing
    i change the quartz on ISO board the red led not work
    can you help me
    best regards
  9. #624
    Jun 2017
    My clip broke because of cable problem (disconnected during software update).
    The problem was corrupted flash on ISO board (missing some software).
    I downloaded ISO board flash dump from this site, flash but still I have problem. Software update fail, but when I remove appliiso.s19 lip works fine (I can do full diagnostic on my car).
    Any idea what should I do. Maybe different dump?
  10. #625
    Jun 2017
    Quote Originally Posted by JareckiPL View Post
    yes, i used this site many many times
    a good write-up
  11. #626
    Aug 2011
    Me have bought 3 consult from
    http://www.ufodiag.com/
    all is crap lose conection all time one me broke apart two send back to fix then one lost in post
    one they fixed got back same crap not vorking then they told me have high quality canclip
    vork good tested vorked one car nov iso light go off this chinese sell only garbage they fix nothing
    always they say fix ask enginer and dont knov vhat so at end you get tired.
  12. #627
    Oct 2017
    heloo image ush megane 2
  13. #628
    sergei5005's Avatar
    Nov 2012
    Bs As
    My Can Clip have same problem. Change 74 % and....error message- "Failure of the reservation of the probe. Try it again and contact technical assistance in case of another failure? . What is the final solution ?? THANKSSSSSSSSSSSS
  14. #629
    sergei5005's Avatar
    Nov 2012
    Bs As
    My Can Clip have same problem. Change 74 % and....error message- "Failure of the reservation of the probe. Try it again and contact technical assistance in case of another failure? . What is the final solution ?? Any help ??? Thankssssssssssssssssssssssssssssssss
  15. #630
    Sep 2009
    tray Renault can clip solutions http://obd2-diag.blogspot.com/p/renault-can-clip.html
  16. The Following User Says Thank You to janusz21 For This Useful Post:
    sergei5005 (24th December, 2017)
