Why you make this complicate,you just read immo data from orig and program with pin on car . ..
Sent from my M2101K6G using Tapatalk
Hi everyone!
I was wondering, to swap my two identical cluster, only need to swap EEPROM and MCU between clusters?
The cluster part numbers are exactly the same: 6Y0920843L, and both of them from 2007.
Both of them have a 93C83WP EEPROM and Micronas 3301 MCU.
I think, because the EEPROM is encrypted, I need to swap the MCU-s, bc that contains the mask for the encryption.
There is a MEGAMOS chip, which I dont know what is it and there isn't any datasheet or information about.
If I'm right, I dont need to program anything, bc everything was on the EEPROM and MCU, I migrated to the new cluster.
Is there somebody who can confirm that? Or somebody who did something like that?
Thanks in advance!
If I help you dont forget to push thanks button
lacy04 (31st December, 2021)
Forget to mention, that I only have VCDS and VAG Commander 3.6. So I cant read it through OBD.
I have a chip programmer, but that is useless, bc the eeprom is encrypted.
For me, the desolder, solder method would be the easiest, if It would work.
And after that, I would not have to alter the odometer to the real value.
And for the cluster swap, I would need the original cluster pin and the used (new) one.
Yes transfer eeprom and flash content with programmer (if mcu not locked) or desolder and replace chips will work. No need to mess wih megamos chip
Post dumps from EEPROM for PIN and km correction.
lacy04 (1st January, 2022)
I will post them on Jan.05. Thank you and Happy New Year to everyone!
Immo ID SKZ7Z0G4215054
VIN TMBJX26Y674200xxx
KM 193888
PIN 02122
Listen to advice from dragoshu
Keep in mind, English is not my native language.
Hi Everyone!
Can somebody match the km, and tell the PIN codes?
The km on the original is around 215.200.
Can I write the new cluster EEPROM in circuit?
I would really need it today. =(
Thanks in advance!
old PIN 01017
lacy04 (6th January, 2022)
Thank you! It worked!
