X-prog m & Golf V Micronas problem - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 68
  1. #16
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by PROCESSOR View Post
    i want to read ST10F280 did any one know wich interface or programmer do that.
    Thanks.
    last update from xprog do it .... 12.02.2010 .....
  2. #17
    calin_bm's Avatar
    near civilization
    Quote Originally Posted by VagSoft View Post
    Yuo must disconnect XTAL from Micronas
    mate,on the datasheets,i saw what & where to do and disconnect pins,i try for more than 20 times,and no luck,still that error with ID...
  3. #18
    DId you just made this up? or did you ever tried it?
    So you are saying: Remove the Hart of the patient, then talk to the patient whats wrong.
  4. #19
    clip crystal to short pins ,or remove from circuit . 100% more accurate read/write
  5. #20
    Hi all.
    I have original XPROG-M.
    - Micronas work fine , 1000% (test only Usb)
    i read and writte ST10F280 ok. 1000% (Test only Usb )
    Good tool
    B.r
  6. #21
    ISTANBUL
    Exclamation
    Quote Originally Posted by valty View Post
    Hi all.
    Good tool
    B.r
    yes yes
  7. #22
    hk
    Quote Originally Posted by calin_bm View Post
    Hello guys,my problem is for those who has an original Xprog-m programmer.Last days I have a dash VDO from a Golf V 2008,inside with a micronas 3297G and my programmer could not read/write the data inside chip,it's show an error "Device ID does not match,ID is 0x 000122B9".Someone has this problem before?an how it can be done?
    Thank you.
    XPROG-M support this with no problem, possible reason from your side maybe wiring connection issue or you turn to TMT for support
  8. #23
    calin_bm's Avatar
    near civilization
    I check and re-ckeck the connections,ot's only 10 wires,not hard to connect,it's harder for exaple on some NEC processors from Renault dashes,so i think that the connections are the last thing to think,the problem is in that ID...
  9. #24
    branco's Avatar
    paris france
    is not your hard or connections
    you must set ID for mcu
    I got same problem with mitsubishi M32C processor from car radio
    ID don't mismatch so you can't read write
    maybe exist special area protection in some mcu and you must
    know ID
    regards
  10. #25
    calin_bm's Avatar
    near civilization
    the software set himself the ID,you select dash > car > Micronas model (3297,3217) and the read,so all you have to do is connect the wires and set up the program.
  11. #26
    Default How to get the ID
    Hello , guys. I want to know how to get the MCU ID and then read the data from it
  12. #27
    calin_bm's Avatar
    near civilization
    yesterday,another golf 2007,another ID problem,anyone else reporting that has such problem like mine?
    thank you.
  13. #28
    DK Veteran stevan's Avatar
    Bosnia
    ID problem mean that you select wrong MCU type.Don't look on Dashboard menu as it is exactly,if you do Golf V,check mcu and maybe need to select Jetta -07.2006.On left panel you see type of MCU.
  14. #29
    i have tested Xprog clone in golf 2007 cady 2008 and work fine
  15. #30
    calin_bm's Avatar
    near civilization
    yep, us too...
    stevan,very good ideea,i will try that.
