Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 68
  1. #31
    Top Poster jarfm's Avatar
    North
    Hi, also I have similar problem, i mean Octavia II after 2007 has different board than in the Xprog schama. Anobody know how to connect this type of board?
  2. #32
    South Africa
    i would also love to know how to read dash. guy claims it is a gti cluster. but the skin belongs to a straight fsi. looks exactly like yours. micronas cdc 3297G. thanks.
  3. #33
    calin_bm's Avatar
    near civilization
    it's like audi a3 micronas cluster,the connections are the same as all micronases,all you need to find is the VDD-VSS points.
  4. #34
    South Africa
    thanks. you dont perhaps hav a diagram. thanks.
  5. #35
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    Quote Originally Posted by calin_bm View Post
    unfortunatley comparing with xprog pictures, we must find more that 2 test points...use cdc3297 connection diagram and knock your self up
    upper,left corner, smd capacitor between the big capacitor and the smd diode, should be vss-vdd...but you can wire the cdc pins too
  6. #36
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ecutoool View Post
    i have tested Xprog clone in golf 2007 cady 2008 and work fine
    did you need to make any modifications on adaptor for these year/models?
  7. #37
    morocco/fbs
    xprog m v 5 micronas = not good
    tested many time on some dash = not working
  8. #38
    i'm using xprog-m to read/write flash on golf5. always working perfect
  9. #39
    PERPETUUM MOBILE
    clone or ori?
  10. #40
    ecutool clone
  11. #41
    PERPETUUM MOBILE
    yours is the green pcb version? this can be an factor also
  12. #42
    never opened it. it's the smaller one in the metal case.
    more important is to use good cable for coax wire, keep coax wire away from power and of course lift the xtal from board in any case. never make it with xtal connected.
  13. #43
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by exe123 View Post
    did you make your coax cable?
  14. #44
    yes because it was shipped without cable for micronas/freescale adapter
  15. #45
    PERPETUUM MOBILE
    yes, indeed, just test my self, it works, the triky part is the length of the coax cable, without it, it dosent move a needle ...
    i still not know the best combination, to read/write one time, i must try several times to bypass the security, is it ok? or it has to do it on first/second try...
    my next question is: the xprog dash module for vw is it any good? someone test it?
