Results 1 to 4 of 4
    Newbie gabilaza's Avatar
    Dec 2021
    US
    Default DACIA DCM 3.4 Clone problem, no acceleration pedal response
    Hello mates, 2 weeks ago i had to clone dcm 3.4 for Dacia Duster. I succesfully read and write flash with KTAG and also read and write eeprom with VVDI Prog by pinout. I put cloned ecu on car, it started ok but i cannot accelerate, acceleration pedal is not recognized.
    This week just for testing changed same type of ecu ( DCM 3.4 ) on a Dacia Logan same engine (1.5 DCI ), this time i just read eeprom from original and write to donor ECU, no flash . Also car start but no acceleration.
    Any advice? Thank you in advance
    leonida's Avatar
    Oct 2016
    Thessaloniki, Greece
    Try write .ori eeprom and .ori flash via OBD ,from original ECU to donor ECU ...
    Dec 2021
    US
    what tool can write eeprom via OBD on this ECU?
    HI try to check if injector code is not lost,same is happent to me after clone renault ecu,just write injector code and try!!!!
