Page 1 of 4 1234 LastLast
Results 1 to 15 of 63
Hybrid View
    Jul 2009
    Default Renault Clip Firmware Upgrade Error
    Hi Guys
    Anyone got the definitive solution for the Clip sensor upgrade problem.
    I'm using Clip v94, when it detects the probe it automatically tries to upgrade the firmware failing at 20%.
    My research here lead me to remove the RSRWIN registration artefacts but to no avail. I found a removal tool (CLIP_registration_remove_v3_d_k.zip ) on this site but it appears to be corrupt. Also noted somebody suggested installing Clip v85 or earlier, but can't find this version on the net.
    The once and for all full solution would be nice.
    DK Veteran BeianM's Avatar
    Nov 2009
    Dorset UK
    Quote Originally Posted by Delboy65 View Post
    Hi Guys
    Did you get this from my link? I just downloaded it from your link above & it has just installed here with no problems. Download & try again.
    v.92 http://www.digital-kaos.co.uk/forums...-v-92-a-46587/
    Im sure v85 is on dk somewhere.
    Do you have wireless connection on? if so turn it off.
    Jul 2009
    I tried the download again this time on a different computer, still winrar reports 'unexpected end of archive'.
    So I dug a bit deeper with a hex editor to check the file headers. The file arrived to me as a zip file. I renamed it rar and it opened correctly. The file within was then given the zip extension and it uncompressed giving me an executable.!!
    The exe is an installer package which runs but asks for an 'Installation Password'. Any ideas?
    As far as wireless goes, the laptop is a stand alone machine and not connected to any network.
    Nov 2009
    Dorset UK
    there is no password, just hit the enter key
    DK Veteran vevepatronu's Avatar
    Jun 2009
    Romania
    try to downgrade your Interface with an older Renault Clip SW (versions that work on WIN 98)
    Jul 2009
    Any links or ftp for older versions??
    I have searched but the only torrent I found has no seeds.
    As for the registration remove software, any password or no password allows the installer to complete but it dosn't write anything to the hard drive!!
    Nov 2009
    Dorset UK
    Strange, it worked on mine!
    List of older soft, see my post here http://www.digital-kaos.co.uk/forums...lip-v96-91580/
    Jul 2009
    I downloaded the v92 version and installed it.
    Exactly the same problem with the need to update sensor firmware !!
    Help please anyone!!
    Jul 2009
    I have all versions from V2 best is V53 I will upload it.
    Feb 2010
    Have a look on the opening page. look under tools and then connections.Check to make sure it is set to disconnected. I had the same prob..Hpoe it works.
  11. #11
    Jul 2009
    Update
    I have now installed V85 as per advice of some other forum members. This time the software detects the interface and goes straight to the vin screen.
    After entering the vin I have full access to all ecu's except Air Bags.
    I then tried with version 94 and the same problem raised its head with it looking to upgrade firmware.
    Anyone experience a need to upgrade after v85?
    It appears the device requires a firmware upgrade sometime after version 85.
  12. #12
    Mar 2010
    hi ive just installed clip and have thr spx registration page , will the above software fix that ?
  13. #13
    Nov 2009
    Dorset UK
    Quote Originally Posted by vrscoventry View Post
    No. you need to run a crack or manually edit the reg. Have a search & you will find it.
  14. #14
    Apr 2010
    Default firmware
    hi, anyone say why somtimes clip launch firmware upgrade at startup of clip? mine stop at 20% and error msg. somtimes firmware upgrading until 96% on probe and fails.
    Clip v88
    Maybe V92 Solve problem?
    thanks, Mikael
  15. #15
    Jun 2010
    I downloaded the v96 version and installed it.
