Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 63
  1. #16
    hi, sorry I don't have other version, maybe anyone here have?
    you think this can solve pb?
  2. #17
    Romania
    Quote Originally Posted by magic_clip View Post
    I read on DK may be have success.
  3. #18
    North West
    Use one of the downloads on the forum - I think by Qrius or Patrian or Diagnose64 - cant remember which - to download all the clip drivers again. uninstall your CLiP from hardware, then try to reinstall all 4 full drivers MAKE SURE YOPU DOWNLOAD THE Files which include about 4 folders/files per driver
    - ALL 4 must be found and met with a message to confirm this when you install them with the clip plugged in vehicle side also - when you update your CLIP again once you are 100% confident you have all 4 drivers I think you will find this is a driver related inability to pull through the matching update firmware files.
    I maybe wrong but this once fixed this exact problem for somebody. They kept getting the failure to update firmware using V94 or V96
    Its worth a try I would think !!
    --- When you install each driver via new hardware wizard make sure each one confirms their installation. Sometimes the hardware wizard dissapears after you direct it to the driver folder for install. Which then follows the next add driver wizard. It could be easily presumed that this driver had installed correctly. However it did not. You must get full confirmation which can be indicated by the start of the non approved windows drivers - continue anyway screen. And visually seeing the drivers folders uploaded to device.
    DOWNLOAD DRIVERS FROM FORUM
    MUST HAVE ALL 4 FOLDERS with multiple driver files inside each of the 4 folders
    Uninstall your CLIP hardware from device manager
    (ijdeally reinstall CLIP I would say)
    PLUG into vehicle, then into laptop
    Manully install drivers from the download driver folders - by poiting them to where you saved them
    Be 100% sure you get all 4 confirmations of drivers being directed to the CLIP
    Re boot after success.
    Open up CLIP again, try to connect and you should get any necessary updates your firmware require without issue. you may find you dont get any message at all about this now.
    Good luck
  4. #19
    hi, thanks for this detailed procedure, I've try it, and :
    sometimes only 2 drivers are detected from computer, and sometimes 4 drivers are fine detected, I install manualy, launch clip, firmware upgrade start, complete to 96% and fails with error message...
    maybe my clone probe is defective?
    strange bug, I don't find diag tool for the probe, to test or flash probe manually.
  5. #20
    Usually if 2 drivers are detected, that happens because the clip is not connected to the car. Please be sure that is connceted and check the cable itself. Hope this help.
  6. #21
    i have firmware upgrade error only when i try to connect my clip to a megane 3, with megane 2 the connection is fully ok.
    i use clip100 whit a clip clone.
    how to make firmware upgrade for use clip with new renault?
    thankyou to everyone this forum is great!
  7. #22
    I downloaded the v96 version and installed it.
    Exactly the same problem with the need to update sensor firmware !!
    Help please anyone!!
  8. #23
    Solution: Run Clip Firmware Upgrade Error tool.BAT.
    To begin your CLip, enjoy!
  9. The Following 3 Users Say Thank You to bolonc For This Useful Post:
    arti1 (28th October, 2023), frigo (12th July, 2014), tamer1024 (7th April, 2018)
  10. #24
    thank you bolonc! i'll try when i connect my clip to a new megane (i have firmware problem only with that car)
  11. #25
    thank you Run Clip Firmware Upgrade Error tool.
    update sensor firmware ++++ is ok
    but
    DEL C:\ASDE\MODULES\APPLIISO.S19
    DEL C:\CLIP\DATA\APPLI\PARAMS\APPLIISO.S19
    is no work
    is-ok
  12. #26
    Member igopippox's Avatar
    Oct 2008
    Quote Originally Posted by jnp1908 View Post
    Good luck
    Please is possible to upload the drivers described in this post ?
  13. #27
    Newbie pepar's Avatar
    Vogtland
    Smile
    Hey, i?ve got uploadet the driver and the firmware error tool...
    i used this driver after i get the firmware error message... now it works fine from clip v96 to v103 and from R19 to Megane 3... if u have after Driver-update still problems to read live data with running clip (velocity, airbagresistors, airconditioning...) especially on megane 3 or laguna 3 reinstall your winXP
    have fun
    i?ve take some Screenshots of the Driversection in winXP... hope it will help someone
    Last edited by pepar; 3rd September, 2010 at 01:45 AM. Reason: take some screenshots
  14. The Following User Says Thank You to pepar For This Useful Post:
  15. #28
    Quote Originally Posted by DIAGNOSE64 View Post
    I have all versions from V2 best is V53 I will upload it.
    any chance of the V53 upload yet please?
  16. #29
    DK Veteran hakimk's Avatar
    france
    i need to thanks
  17. #30
    Sep 2010
    Default reprog
    What is the " Renault Reprog v89 for Clip v100" disc?
