Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
  1. #31
    hello to all
    my problem is this: the interface can't find the USB, in DK they say there is a problem in AN2135SC, till now i coudn't find it
    can any one here helps me?
    thanks in advance
  2. #32
    Newbie dielektrik's Avatar
    Default CAN CLIP repairing (HUB, cant reflash, driver problems)
    Quote Originally Posted by bmn2090 View Post
    hello to all
    thanks in advance
    Hi All,
    Usaly problem are:
    1. Cant find USB Generic (or Cypress) HUB, ofcoure can find any usb device. Problem in HUB - CY7xxxx, electrolitic capacitor (yelow), soldering problems
    2. Cant find (install ISO or CAN board) i talk not about drivers problem. This case focus your attention on
    2.1. If cant find CAN - HUB Cy7xxxx, power IC +3.3V ( small one w/ 5pins, exist on CAN and ISO pcb), AN2135SC, EEPROM (24Cxx), CPU FLASH RAM CPLD (CY370xxxx) soldering or each of these.
    2.2. ISO - HUB, IC +3,3V on ISO board, AN2135SC under ISO PCB.
    3. Dirver ok, CAN and ISO GREEN LED light. Clip cant be reflashed from CLIP SW. Check witch GREEN LED (CAN or ISO) blinking when SW try flashing Sonde. Resolder FLASH and CPLD on CAN or ISO board.
    Often we replace HUB, AN25xx, FLASH and CPLD (100pin QFP) and do resdering.
    Keep your attention - good Sonde CLip should pass SW update from any SW (V35....V100). If it could not pass it means you have more job what yuo think =)
  3. #33
    Thanks all for the replys and solutions.
    I'll try them today, i hope they work.
    My problem is with the sensor firmware update error with clip v96.
  4. #34
    Thumbs up An early version of clip to downgrade your china clone
    Hello everyone. I put online an old version of the V55 clip. It runs on WinXP and did not register the SPX.
    You can downgrade your clone clip with it.
    Very good website.
    Contact me by private message for the rapidshare link.
    Last edited by G22gegenne; 14th October, 2010 at 07:36 PM. Reason: prohibited to place a link in the post
  5. #35
    emember plugging the car before installing drivers, to find
  6. #36
    Romania
    Hello I have the same problem. You can send to me the link? Thanks.
  7. #37
    I have the same problem with firmware error.
  8. #38
    europe
    I have china clone first time when send me clip work with v95 i have same error firmware problem i send back clip to china and i get new one with version v85 now i need new version to install what is the best working version for china clip//?
  9. #39
    DK Veteran BeianM's Avatar
    Dorset UK
    Quote Originally Posted by VDO View Post
    If it works on your car then upgrading is not needed. You may find that you can use the reprog disk without ren.net access. Newer versions have firmware updates that may mess up the sonda & a new database that is all. If you search the net you will find newer software if you want to try it.
  10. #40
    I clip does not work with version 81 and above.
    Also works with version 55, but for some reason does not try to update it.
  11. #41
    Polska
    How proud and how to upload firmware to reanult clip?
  12. #42
    Feb 2011
    Default Firmware Upgrade Error
    Quote Originally Posted by bolonc View Post
    Solution: Run Clip Firmware Upgrade Error tool.BAT.
    To begin your CLip, enjoy!
    Hello I have problem with my clip any solution dont help firmware was not upgraded
  13. #43
    Feb 2011
    Hi I have the same problem with firmware error.Any solution not found.
  14. #44
    Feb 2011
    It's found?? CLIP_registration_remove_v3_d_k.zip thanks for help
  15. #45
    cipijoint's Avatar
    same problem too with 3 can clips . all this problems begin since 6 months. before was only usb problems .
    nowdays clip is wrong manufactured tools...
    dont talk a lot and nothing
