Results 1 to 1 of 1
    Apr 2016
    UK
    Default R56 DME Dump Read ISN
    Hi everyone,
    I have replaced my DME on my r56 one 2008 as it was causing some valvetronic problems. Unfortunately someone has already modified the DME software and now I can't clone the DME and transfer it to the new one as I get the same problem with the valvetronic again. The new DME works fine but the problem is that the CAS is not synced.
    I don't have a cable to get a CAS dump and I don't really want to remove the dashboard in order to replace the CAS or read it. I have DME full dump using ktag of both old and new DME units. Can someone please transfer all the IMMO, VO, VIN, ISN data from the old dump to the new one?
    Also I guess that will work and the car would be able to start.
    Cheers
    new_dme_dump.zip
    old_dme_dump.zip
