Results 1 to 15 of 27
    Default Fiat IAW 59F.M3 -*Need pin login from dump*-
    *got the pin code
    I need the pin code to login to the ecu and program in new keys.
    I can not get the login code from Fiat as I replaced the ecu so my cars vin wont match up so can't get the pin.
    Does anyone know if the dump from the galletto even contains the contents of the 95080 or do I need to cut open the ecu even more and read the chip direct?
    not-my friend
    you need to read spi
    to get Pin from ecu
    regards
    GB
    HELLO EXACT FRIEND YOU NEED READ SPI 95080 FOR PIN CODE.
    BR
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by paul_12345 View Post
    you can do it in other way easly if you just want to replace ECU
    use decode from galleto
    so your ecu is virgin put it back and turn on wait until car accept code if your key and bsi are ok !!!
    no need to get pin code from ecu ....
    Quote Originally Posted by youssef70 View Post
    Dont you need access to the 95080 to make it a virgin? Also not sure if it will help in my case, I was thinking I could put back the old computer and then add on the virgin ecu so it uses my old key, then get the oringal code from fiat, but the pin code will still be the different one from the new ecu? So still would be in the same situation.
    i dont think you can get the pin from engine ecu. if you can get to the bsi and read dump i can get the pin for you.
    regards
    Quote Originally Posted by simon77 View Post
    regards
    Thanks, from the icc im*o website I know on the 59f lower than m3 the pin code is stored on the body computer, but on m3 its in the chip on the engine ecu.
    I think I'll try and get a cheap ecu to read so I still have my car running if I mess it up.
    GB
    HELLO FRIEND I USE THIS METHOD , THE PIN CODE IS INTO
    THE EPROM 95080.
    BEST REGARDS
    GB
    THEN THE FILE WITH SOFT FILTER
    BR
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by angmar View Post
    THE EPROM 95080.
    BEST REGARDS
    and wich tool is used to read or simply you use needle ?
    is it possible to solder in those points ?
    does anyone know if you can hook the ecu on the bench then just use serial clock and serial data in and out pins to read?
  13. #13
    gepakg's Avatar
    Serbia
    read body module,93c66 inside pin,easiest way
    regards Gepa
  14. #14
    Top Poster + Kanaan's Avatar
    in my car
    1) the Pin code is writen inside the BSI you need to read the dump from BSI and post .
    2) now check your ecu number and the "HW" value . if the HW > 100 Then you can make the ecu vergin and if not you cant make it version .
    3) if the HW is greater than 100 then you need to wake up the ecu in boot mode then you can read and write using galleto to it .
    4) if you shere your problem with the original ecu maybe we can help you fixing it .
    Good luck
    Kanaan
    God does not play dice with the universe . (Einstein)
    if anything can go wrong it will . (Morphy laws)
  15. #15
    Quote Originally Posted by gepakg View Post
    regards Gepa
    You can't get the pin from the 93c66 in the body computer for the m3 version can you? only in the < m3 versions
