pin renault from dump - Page 25
Page 25 of 27 FirstFirst ... 152021222324252627 LastLast
Results 361 to 375 of 404
  1. #361
    Senior Member ana_11's Avatar
    EU
    Please help, need pin to opel movano 2006y.
    Uch 95080.
    Thx
    Best Regards
    Simon
  2. #362
    The land of choice
    DA FF 5A 51 D1 FB
  3. The Following User Says Thank You to Milkman For This Useful Post:
    ana_11 (1st June, 2013)
  4. #363
    EU
    Quote Originally Posted by Milkman View Post
    DA FF 5A 51 D1 FB
    Thanks, pin OK.
    Best Regards
    Simon
  5. #364
    Apr 2011
    need pin code from dump Clio III UCH
    Thanks in advanced
    Mat
  6. #365
    topclef's Avatar
    PIN : CC 53 32 B7 30 70
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  7. The Following User Says Thank You to topclef For This Useful Post:
    mcgywer (4th July, 2013)
  8. #366
    Apr 2016
    Hello, I've recently got a Trafic van and need to replace/ program an injector - could anyone kindly provide me with the pin code for Renault Trafic cmg64? Many many thanks!
  9. #367
    rideon's Avatar
    RO
    Are u sure that cmg64 is not the paint code
    A failure will not appear till a unit has passed final inspection
  10. #368
    Apr 2016
    Hi rideon, thanks for your reply.
    Yes, you are right - I'd just found out and logged in to delete my post before someone saw it - too late, sorry!
    It's the only code in my maintenance booklet - I guess I'll have to go to a dealer.
  11. #369
    Jun 2016
    Budapest HUNGARY
    Megane 1 immo problem
    The car after ignition ON rewrite immo eeprom
    Please check crc the file THX
  12. #370
    EU
    Default need megane uch pin calulate
    Hi Friends
    can i ask for pin code for megane 2000y pin code
    UCH hc05 3G96A
    Thanks in advance
    unar
  13. #371
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  14. The Following User Says Thank You to kiszka For This Useful Post:
    unar (31st July, 2018)
  15. #372
    Nov 2014
    Turkey / İstanbul
    Can you write password
  16. #373
    Feb 2019
    Default please help unlock and start my car thank you
    Quote Originally Posted by gabigafu View Post
    your code is A7 23 D6 A8 28 1C
    hi Gabigafu
    cann you please help me i have renault modus i verginise the UCH and now may keys dont work and car dont start do you ned dump file to unlock it ?i tried several tine to unlock but without success. also the lock unlock button inside doesnt work
    UCH is : BCM L2CR 8200497363 and the other one motor ecu DELPHI DCM 1.2
    VIN : VF1JP0D0533073819
    please help thank you
  17. #374
    Feb 2019
    please code for renault Modus 1.5dci UCH is vergined BCM L2CR+ 8200497363 00080535
    Motor ECU ELPHI DCM 1.2 S/N 82802486 MXG
    if you ned dump file i ll send it to you
    thank you
  18. #375
    Apr 2019
    UK
    hi everyone can someone please give me 13 digit code for renault espace from eeprom.
    vin is VF1JK0CB34328036
