Page 4 of 27 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 404
  1. #46
    mihai_vyt's Avatar
    Default pin
    pin ok???????
  2. #47
    PierreTheron's Avatar
    Centurion,South Africa
    Default Clio 2,3?uch
    Quote Originally Posted by mihai_vyt View Post
    pin ok???????
    Have not got this car at my shop yet to test. Immo light stays flashing and car has been out of action for three years as no one can solve it . Got uch by me , still waiting for car to get towed to me.
    Will update on this as soon as i have car by me to break it a bit more.
    Got car by me now , think something wrong with uch .
    Here are dump from uch n2 in the car -no flashing immo light.
    Here are dump from other uch n3 i had ,seems uncoded? but got flashing immo light.
    Can see vin in first dump so i believe files are okay.
    thanks for help .
    Can some give me the pin on these files?
  3. #48
    Default Clio2/3 uch
    Quote Originally Posted by PierreTheron View Post
    thanks for help .
    Just a repost to get it on the list for today....
  4. #49
    gokey's Avatar
    C53D57FD5EBF
    F13D5CFD5FFC
  5. #50
    Quote Originally Posted by gokey View Post
    C53D57FD5EBF
    F13D5CFD5FFC
    Thanks GOKey.
    Just an update on this vehicle.
    I resoldered all possible parts in uch ,plugged it into car and had immo light flashing.
    Got connection with clip to uch and immo code was okay.
    Tried to clear fault codes in ecu , did not allow me to do that.
    Starter did not want to go into cranking cycle.
    Checked airbag module and was crash locked.
    Left ignition on for 20 minutes. got back to car and it cranked.
    Cleared all fault codes in ecu and car started.
    So I have got another runner!!.
    Car still got misfire due to two injectors that does not spray.
    Not too bad for a vehicle that did not run in three years time.
    Thanks for all Help.
  6. #51
    hello
    I try to put the pincode in the clip, to configure a new Uch and keys. If possible, try also the file of my virgin UCH.
    I have a clio2 dci year 2004-2005. This file is the dump of the 93c66
  7. #52
    gokey's Avatar
    94F5BCF9DA3C
  8. #53
    thanks, I'll try the code.
    Do you have a file for my virgin Uch?
  9. #54
    Need pin code for uch.
    Thanks in advance...
    Pierre
  10. #55
    DK Veteran cleevesy's Avatar
    Think dump is bad bud read it again.
  11. #56
    Default Pin from dump uch
    Quote Originally Posted by cleevesy View Post
    Think dump is bad but read it again.
    I think i got it right this time.
  12. #57
    gokey's Avatar
    pin = 3954
  13. #58
    BIH
    clio 2 uch n3 attached, but clip seek after sales code and does not accept my pin 5bd9ae3fa412 which I think is correct,pcf7936 prepared with zbull.Please help,whether in applying the new immobilizer key in clip
  14. #59
    BIH
    file is heare i make mistake
  15. #60
    Your pin is: 5B D9 AE 3F A4 12 is the pin from uch , maybe your fault is clip do you have another tool you can match the key with.
