Results 1 to 9 of 9
    treo's Avatar
    R
    Default Iveco dash problem
    Hi I have a Iveco year 2003 with VDO instrument cluster Iveco Nr.504055190,inside 93S56,after readig dump was corupt becouse the speedometer doesn't work and for 1km route odo register 5km.I need dump and i want to know if 93S56 can be replaced by 93C56.
    BR
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by treo View Post
    BR
    Try one of these....
    Junior Member angelcom's Avatar
    cars land
    this dash works well with 93c56
    you can replace
    BR.
    treo's Avatar
    R
    I will try to change eprom with dump from Drpeter next week becouse the car is in a long trip to Italy.
    Thanks for your help.
    Land of Rocks
    If the pins 6 and 7 are conected on pcb you can replace only with 93LCXX.
    heeeeeeeeeeeeeeeeelp = Hello, I have a problem with VDO 93s56 - 1551.....board that has 4 connection, any dump that I have when isprogramiram show display, but the scale does not work - (. Is there a solution
    heeeelp, dump for iveco daily vdo 93s56 , Thanks
    Default IVECO DAILY ,heelp dump
    help, for dump iveco daily vdo 93s56 Panel with 4 konetor. No.
    1551.72.010.06
    Default Change mileage Iveco Daily VDO 1551.60100100 with 93S56
    H, I need to change mileage to 131000km. There is a 93S56.
    It's a VDO dash:
    Iveco - Nr: 500366403
    Typ: 1551.60100100
