is the immo light flash . when you open switch check what it does it should come on then flash a fault code then stay on.
maybe the problem is key. Have you got another key program and working? the key is new? if you are adding key look if the transponder is correct, there are 2 or 3 diferents colours for nissan.
Excuse my english, it's poor
turn off the key light flashes,
while turning the key the light is fixed.
key color is blue
hi
now only have error P1611 and error P1610.
and pin not work,maybe pin is error.
make sure bat is 12v constant leave ignition on for 30 mins then try pin 1 if that dosnt work close switch open leave on for 30 mins try pin 2
i will try tommorow to check your pin and confirm.
now you change quartz has there been a change or are things the same
hi
conect 12v in pin 1 immu?
this is pin correct 1559?
good to here is all running now
regards
hi
i have 12v in pin 1 immu.
hello
nobody has an idea, the code will not give?
I turn the key I try encoding with x-431 launch, when put my code, says always immu fail.
my code is 0679,i read tms and in program is this code.
disconect key light flash,and conect and light is fixed
the car stopped working, never worked
i have error P1611 AND 1610 in ecu and in nats 5
AGAIN as i told you before, check your crankshaft sensor or maybe one sensor is damage!!!
hi did you slove your problem ???
I think i have same problem on same car.
I need pin and i'll change quartz.
