immo problem Landrover Range Rover 2.5 td - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Bulgaria, Sofia
    Hi, I have a problem with RANGE ROVER 2.5 TD (BMW Engin) immobilizer is activated and the engine will not start. The central locking does not work (either by remote control or by a key in the driver's door). Receiver for the remote control does not work - after replacement of the car does not accept the code key.
    I need a PIN code or IMMO off. Apply all pending dump of ECU and photos.Memory NOT SMD, the program is different for SMD . Without memory - ENGINE RUN
  2. #17
    DK Veteran thomas76's Avatar
    Oct 2010
    Quote Originally Posted by Nevidimia View Post
    I delete 2 x B58 and engine start ?
  3. #18
    HI
    Here my dumps:
    If anyone could mmo off.
  4. #19
    Nov 2010
    Seafront
    Hi, i have such a car in my shop now, i tried the dil 28 swap but it does not start, found a solution from Aetool - program the
    two 93c46 - disconect the immobox and cut yellow cables .
    Does anyone know where i can find the immobox ?
    I found the bodycontroler under the driver seat - but there is no yellow cable.
    Anyone got a little hint for me ? Thanks buddys
  5. #20
    foxtec800's Avatar
    Quote Originally Posted by tuberider View Post
    does anyone know the black/yellow wire location on becm terminals ?
  6. #21
    Quote Originally Posted by foxtec800 View Post
    I Have also programmed 2x 93c46 as shown in immo dec 3 - it is asking me to cut ywllow and black wire from 'transponder' box - Anyone know where this is??? Thanks *********SOLVED - I used otocheck - worked perfectly *************
  7. #22
    Senior Member gixxer's Avatar
    Mar 2009
    Europe
    Hello
    What solution? I have this ECU no SMD eprom. I try "ecunxx dec 3" remove immo but nothing car start 1sec after stop.
    Thank you
  8. #23
    Mar 2009
    Europe
    Bulgaria, Sofia
    RANGE ROVER 2.5 TD (BMW Engin) -> IMMO off solution -> Memory 2x 93c46 NOT SMD, REMOVE 2 memory -> ENGINE RUN !!!
    It`s not necessary to cut wire . Right is many times TEST OK
  10. The Following 2 Users Say Thank You to Nevidimia For This Useful Post:
    csavargo2 (25th August, 2021), gixxer (4th November, 2013)
