Results 1 to 4 of 4
    Oct 2021
    Default A8 D2 Immo Code Reading
    i'm searching for a way to read my Immo Code from my A8 D2 (MJ 2000) with Crypto.
    I need the Login Code 'cause i want to replace the old Cluster. It malfunctions not directly but the Screen in the middle ist blurry and slowly dying..
    A 'new' Cluster is already there but i have absolutly no experience at this sadly.
    I tried to get a dumpo from the Cluster but HxD only reads two lines, all other lines are just 55 (FF in hex).
    The New Cluster has a 24C17 Chip, i guess the original Cluster too.
    Also tired DigiProg 3 to read EEPROM, that didnt work aswell...
    even tried to read the EEPROM from the new Cluster with a Programmeer directly of the Chip... didnt work..
    Could somebody introduce me how to get a correct Dump and how i can get the Login of the Originial Cluster and of the Replacement aswell?
    If all of it didnt work is there any way to do a Factory Reset to a used Cluster?
    In that Case i could take it and get it done by the local Audi Dealer i think, but they need a "unused" Cluster (or factory reset)
    Greetings from Germany, hopefully sombody can finally help me...
    rafal's Avatar
    Jul 2010
    UK - PL
    use better programmer and read eeprom - that's all
    need help
    now my goal is to buy xp-005
    who will help?
    Oct 2021
    Are there any recommendations for a better Reader?
    Precxedure is the same i guess?
    So clip it on the EEPROM or is there a Reader to do it via OBDII?
    Also tried tools like VAG Commander etc..
    rafal's Avatar
    Jul 2010
    UK - PL
    desolder and read................
    need help
    who will help?
