Here is immo off, pass in PM
kevinstone2010 (17th March, 2022), lokj (21st March, 2022)
thank you master, but internal rom memory fault and limp mode fault on my diagnostic scanner
here's my ECU label , don't mind the file name my mistake
here worked file 100%
before ask pass USE thnx Button
Try:
WBR, Marek
Please do not spam my PM asking for help.
Use forum, that is why we are here.
not working ..... immobilizer fault on my scanner
i have ECU that has no immobilizer, no smartra on the car same label board,same engine number sim2k-341 sorento 2.4L and i try to connect it but does'nt start on the car that has immobilizer box in it and no fault detected can you check this dump file maybe you can modified it, or something missing on the system, i tried to pull-out the immobox/smartra but same not starting
نعم خارج sim2k-341
pass 0987
abrhem (10th May, 2022), elitricista (24th April, 2024), kevinstone2010 (30th March, 2022), sharpshooter86 (30th March, 2024)
ples pass
hello
i need immo off
lotfree (19th November, 2022)
