    Default opel 1.8 1.6v ecu how repair
    i have problem which temperature and fan in opel zafira 2001 1.8 16v. I think it's problem in ecu.
    Have some one solution to repair this ecu??
    ecu GM 90 560 476
    Have you read the fault codes? Then post them. It maybe a little bit simpler than you think.
    Thumbs up
    For example, it is more likely a faulty temperature sensor, sending the wrong signal to the ecu. Generally speaking, such faults are rarely caused by a faulty ecu.
    on ecu and "fan ecu" no fault, temperature sensor new, "fan ecu" i change for another car(the same , working), when ingintion on all fan was working, dont work temperature on dash.
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by daw21 View Post
    Sorry .. old Thread.
    I also think this is faulty ecu.
    Have got Zafira A 18XE with same problem .
    1.Fan running when ignition on (Cold)
    2.No Spanner Light
    3.No Ecu light
    4. Car does not start
    5. Cannot connect to ecu with Op-Com.
    I Leave the car till lunch time in the sun.
    1. Fan not running when ignition on.
    2. Spanner light on .
    3. Ecu light on.
    4. Car Starts.
    5 . Can connect to ecu with Op-Com.
    So i wiggled ecu plugs and found car to die when I move the one.
    Checked ecu plugs and was okay.
    Decided to Open Siemens ECU and found broken off aluminium wires inside going from aluminium casing to ecu pins .
    Foocked up The ecu while trying to remove the slime with brush and solvent. (Did not see all the other thin gold wires inside until i put under spy glass)
    Just an update.
    Got S/Hand Ecu set pre-coded with correct software and chips for car from e-bay seller .... ecu express.co.uk
    Plugged in and car was Runner .
    I mounted the ecu on rubber mountings to the engine.
    Hope this will help to prevent damage to those thin wires inside the ecu.
