Results 1 to 4 of 4
    Mar 2022
    Bulgaria
    Default VW Golf 7 9439761 Front Passenger's Side Airbag Igniter B100A Short to Ground
    The airbag lamp has turned on after I went to a car wash (I guess the guys there have cleaned under my front right seat and have touched the cables underneath)
    The question is what to do next?
    1 Fault Found:
    9439761 - Front Passenger's Side Airbag Igniter
    B100A 11 [137] - Short to Ground
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 263579 km
    Date: 2022.03.28
    Time: 18:09:20
    I cleared it but it comes immediately back on...
    The cables underneath don't seem to have any damage...
    Should I disconnect the battery and try reclipping the sockets under the seat...
    Thank you in advance!
    fuzz1's Avatar
    Jul 2019
    Disconnecting battery will probably not clear the fault. It looks like a physical problem. Most likely wiring issues. Diconnect igniter and replace it with a resistor just to check.
    Mar 2022
    Bulgaria
    Quote Originally Posted by fuzz1 View Post
    Ok, If I check with this ( https://www.youtube.com/watch?v=c16S37sJ0qI) and if it's a wiring problem, what must be the resistance levels - something like N/A?
    Because only the wires have been touched.
    Mar 2022
    Bulgaria
    Up!Up!Up!Up!Up!Up!
