Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 121
  1. #31
    I'm not already Top Poster. But I have a problem and not how to solve. Citroen Xsara Picasso 1.6 HDI - original Ecu 0281011233 - EDC16C3 this ecu is damaged the software. I changed the ECU for a ecu 0281011802. I coded the ecu. The car starts, but I climb the rail excess pressure and stops.
    According to Peugeot, is a parameter coded in the coding manual with the PPS. But I haven,t that parameter in the diagnosis.
    I tried several soft and I can not run properly. Someone can help me. Or send a correct one EDC16C3 soft ref 0281011233
    Thank you.
  2. #32
    france
    please pass at( no email addresses to be posted no more chances !!! ) thanxxx advonce.
  3. #33
    ROBERTby2000's Avatar
    in electronics
    pasw plsss .....thanks
    Quote Originally Posted by benci1982 View Post
    here is how it should be given the checksum for edc16 psa and citroen ecu.
    this method not for calc checksum for immo off!!!!!!!!!!!!
    pass for file is only for top poster+ and up!!!!!!!
    pass to pm
  4. #34
    benci1982's Avatar
    Slovakia :((
    Quote Originally Posted by InfoPerformance View Post
    Thank you.
    hi. the 0281011233 ecu is edc16c39, and the 0281011802 is edc16c34 ecu. So I is not never going to be good
    sorry for bad english
    I helped you, press thanks button
  5. The Following User Says Thank You to benci1982 For This Useful Post:
    clauberty (19th April, 2013)
  6. #35
    Hi, please pass
  7. #36
    BRASIL / SUL
    pass please
  8. #37
    Hi, please pass
  9. #38
    Right. but the reference 0,281,011,233 in Peugeot no longer manufactured and replacement of this is a ecu edc16c34. are compatible for the same vehicle but can not pass data between them. The problem is that I have information from a edc16c34 ecu virgin. But I have problems in this car because it uses a different fuel regulator. And the car is accelerating because the sensor does not cut fuel pressure regulardor. And I can not find software compatible for this car.
  10. #39
    Member umut60's Avatar
    May 2011
    please pass
  11. #40
    Member ademram's Avatar
    please pass ( no addys to be posted ) THNXX
  12. #41
    pass please
  13. #42
    tinchocbr's Avatar
    In my house
    pass to pm
    I need the pass please.
    Grettings
  14. #43
    PLEAS I NEED PASWORD
  15. #44
    benci1982's Avatar
    Slovakia :((
    Use any, good luck for everyone. are no more secretive.
    Have all the same, because many people use.
    I just do not do it, if you like things come out
    I hate two-faced people!!!!!!!!
    (sorry for bad english)
    The pass is: edc16 checksum
  16. The Following 20 Users Say Thank You to benci1982 For This Useful Post:
    abdonete (30th August, 2015), amlop (12th March, 2024), auto421 (19th June, 2014), clauberty (19th April, 2013), dzamine670 (24th February, 2019), elecautocr (14th February, 2019), enteran (24th September, 2014), galiza (20th February, 2020), javiere (29th October, 2014), line44 (21st March, 2022), MARIKO (20th July, 2017), pagautas (4th April, 2015), rocris (1st August, 2017), scaro (25th April, 2019), sofiane (29th July, 2016), suki1968 (6th June, 2022), wodorof (20th January, 2024), XJTAG (18th November, 2017), zenosarbu (25th October, 2014), zigzag2588 (9th June, 2014)
  17. #45
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    pass to pm
    Hi mate , please send pass.
    BR
    kasim
