Page 1 of 9 123456 ... LastLast
Results 1 to 15 of 121
    benci1982's Avatar
    Slovakia :((
    Default PSA ecu bosch 16c34, 16c39, login+checksum
    if someone ecu change in your car and you want to use used ecu, should not be to the virgin mode, i calculate the checksum of the new login. the car start and no errors. write me when problems are up
  2. The Following 4 Users Say Thank You to benci1982 For This Useful Post:
    absetup (25th October, 2016), elecautocr (14th February, 2019), elephantul (19th November, 2013), ivankurtev (2nd April, 2015)
  3. #2
    HI
    DONT UNDERSTAND!
    can you immo off edc16 psa?
    Hi. I have recently bought a 307 1.6hdi 9HY, euro3, but engine ECU is missing. I have another ecu from another car, it is the same EDC16c34, can you help me make it work? What do you need?
    benci1982's Avatar
    Slovakia :((
    everyone was using immo off for psa and citroen???
    look 1 post!!!
    Youneselm's Avatar
    Nov 2010
    how did you do it?
    verry interesting.
    benci1982's Avatar
    Slovakia :((
    I will not tell, because then I will have a lot of people are smart. If you need help write to me. Have I nice day
    I helped you, press thanks button
    Top Poster + mecanodiag's Avatar
    france
    Thumbs up
    Quote Originally Posted by benci1982 View Post
    hi i want to use a used ECU for citroen 1.6 HDI EDC16C34
    The old is 0 281 011 802
    the used 0 281 013 872 or 0281 012 528 its possible or no ?
    thank you
    mastaflex's Avatar
    Jan 2009
    FR47310
    0 281 011 802 --> EDC16C34 2.10
    0 281 013 872 --> EDC16C34 4.11 for 1.6 HDI
    0 281 012 528 --> for 1.4 HDI
  10. #9
    joubliss's Avatar
    Far away
    i already changed ecu for edc16c34 and program the code pin without any problem....
    the current problem is when u make immo off in adc16 psa the ecu enter in MODE DEGRADED (dont go up 3000 tr/min) if u have a solution of this immo off its more interessting....
    Job
  11. #10
    rossoelab's Avatar
    Italia
    same problem happened with peugeot 307 (not more than 3000 rpm) after writing ECU
    injectors were scodificati, so I've recoded
    deleted the data found within the construction vehicle ECU
    (such as manual or automatic transmission .... etc etc etc)
    solved by downloading Lexia
    maybe it's the same problem, I hope I was of help
  12. #11
    benci1982's Avatar
    Slovakia :((
    here is how it should be given the checksum for edc16 psa and citroen ecu.
    this method not for calc checksum for immo off!!!!!!!!!!!!
    pass for file is only for top poster+ and up!!!!!!!
    pass to pm
  13. The Following 33 Users Say Thank You to benci1982 For This Useful Post:
    AIDIN R O (23rd January, 2024), aktifland (22nd August, 2020), alclot (15th April, 2014), auto421 (19th June, 2014), bugarcek (27th November, 2014), dark69 (12th November, 2014), digital4u (2nd January, 2020), dragoshu (6th May, 2021), ferchu2323 (3rd April, 2019), galiza (20th February, 2020), garagetech (31st March, 2014), geocity (27th January, 2024), gerasimov (9th December, 2013), giani03 (27th February, 2014), gintaras (5th November, 2014), gobe (23rd August, 2018), gogoli (3rd May, 2014), hamdaniptt (25th April, 2021), Imou01 (4th August, 2017), jdavidleo (12th March, 2021), jovial (21st July, 2015), line44 (21st March, 2022), maybach_ (22nd September, 2014), MOBILTRONIC (5th November, 2014), paulolad (13th March, 2018), Serg1o (15th December, 2020), Simo Lahrach (6th June, 2016), stoyanov (24th November, 2016), tecnoplaga (3rd January, 2020), wodorof (20th January, 2024), XJTAG (18th November, 2017), zaza (16th November, 2023), zmeiarm (24th September, 2014)
  14. #12
    Dec 2010
    please pass
    pass to pm
  15. The Following 2 Users Say Thank You to eduardo74 For This Useful Post:
    adelamar1 (22nd September, 2014), hamdaniptt (25th April, 2021)
  16. #13
    Default passssssss pleeeeeease
    pass to pm
    please pass
  17. The Following User Says Thank You to cavignac For This Useful Post:
  18. #14
    PLEASE PASWORD
    AND THANKS
  19. #15
    PLEASE!! pass..
