I looking for some soft and schema for repair FORD radios with LOCKED13. Who want to help me? Maybe someone have sotution for this problem? Thanks...
Schemat to można rozrysować z urządzenia ale soft jest w zabezpieczonym procku i tu jest problem.
reset tool shema
thanks, maybe someone have a dump for this...
Unfortunately, no hex file
Who knows what are the integrated circuit?? Thanks for all...
No problem is read this protect PIC
If you need to fly the number code, send the serial
I thank you for the efforts
Hi...
Test post
I made this unlocker to run on a PIC16F876. Both versions of my unlocker pictured here used the same mcu (I may have used an 18F252 in later versions).
I've attached a better .sch that you can use, sadly I cannot release the .hex as this is now not mine to release.
Also attached is what I think was the first prototype.
BTW, this unlocker was made my reverse engineering the ETL signals. Really VERY simple.
Good luck.
