Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    Croatia
    You have to just keep on trying! It will be a pain to fulfill the test the first time, but you will became good at it in few years. Sad but true. Of course, I suppose your other actual values like acell. sensor, steering wheel sensor, ABS sensors, engine and trans free of faults are OK.
    Cheers
    If You want to thank me or some other forum member use the Thanks button.
  2. #32
    DK Veteran agabna's Avatar
    hello
    to short ur time u have to check the acual value first
    for the system (switches+rpm senor+esp sensors+steering angle)
    if any sensoer is not working the test mode will nt shut down
    some times it close the test mod after actuations which can be done after erasing the trouble code
    can u give me the chs no for the car
  3. #33
    dunnnia's Avatar
    LT
    Hi,check all actual values of all sensors,someone did'nt work corectly.
  4. #34
    hello
    to end drive test mod is not the same in all the mb cars it depends on the car eps system and year model
    here is example for s class 220 065
    it for using with the das system
  5. #35
    if any sensoers doest work correctly try to change it by other one to end the driving test all the sensoers should be 100%
  6. #36
    Top Poster gigabyte's Avatar
    All sensors seems to be ok but I'll check everything again
  7. #37
    Hello friends,
    Finally I fixed the car. Now everything is really ok Thanks to all of you for the help!
  8. #38
    please let us know what you did
  9. #39
    So, the second sensor was damaged too, it was second hand, not new. So for that reason the test didn't switch off. Today another e-class came to me with the same sensors. I replaced it just to turn off the Test. It gone after a little driving around. Not a figure of eight or circles. Just 1-2 cornering to the opposite direction and one 90 degree cornering and after that it turn off. So the above pics from DAS and WIS are correct. Another thing is that everything must really works. Actual values ware ok with the second hand sensor but it seems that something else didn't work in it.
  10. #40
    florinyes's Avatar
    London Middlesex
    Glad to hear you got it sorted matey..
    Ta ta
  11. #41
    I'm having a similar problem on an 02 C320. Saying Roat Test Active.
  12. #42
    i need more detail for you car type(202-210-203-220) our the first 6 diget in the chs to give you full detail to fix it
  13. #43
    Member lovelyirshad's Avatar
    this is very easy function man just active the drive test remove star diagnosis press esp off switch and drive withing 10 sec you turn steering up to 90 digree and the light will flash and then goes off
    that it
  14. #44
    Jan 2016
    Apologies for resurrecting an old thread, but must give thanks to Dajan2009 and agabna for your very helpful information. Thank you, much appreciated.
    Had a frustrating day with similar issue on W168 03 A190. DAS would not clear fault / light and fell into "Road test not performed" loop. Tried L-R-L-R steering angle reset, driving in 8`s and circles unsuccessfully.
    Couldn`t find road test requirements in WIS but all good now I have learned correct procedure.
