Results 1 to 3 of 3
    Jul 2022
    Default Volvo v60 Airbag SRS error
    Hi! I own a 2015 Volvo V60 plug-in hybrid and I had to change the seatbelts on the car, and with the new seatbelts and everything I know have an Airbag SRS error code on the dash, and on the tester the code was:
    B00791B
    Driver Seatbelt Pretensioner B Deployment Control
    - Resistance too high
    - Permanent
    Can you guys help me out on how to resolve this issue or clear the error code? Because if I try and clear it it comes back up again. Thanks!
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Disconnect this pretensioner and join resistor 2,2ohm then try clear errors ...check in parameters resistance pretensioner ?
    Best regards.
    Dragon
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Volvo did a recall on the pretensioner under the driver seat and replaced them with a cap which still blows after crash, check under driver seat for some black furry tape with wires leading too it. Replace the cap with a resistor.
    Or if the car hasn't had the recall then did you replace the seatbelt and also the pretensioner?
