Results 1 to 13 of 13
    Sep 2008
    Default xbox xclamp fix parts needed
    can anybody tell me the parts needed for xclamp fix please
    size of machine screws?
    size of metel washers?
    size of nylon washers?
    preff correct sizes so dont need to mess drilling case ect....
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Buy this kit from ebay mate. This is the ones i use.
    Next day delivery as well which is always a bonus.
    XBOX 360 X Clamp Fix Kit RROD Xclamp Repair & HQ Paste on eBay (end time 14-Mar-10 09:29:35 GMT)
    Patience is a virtue.
    Sep 2008
    dont u need nylon washers tho??
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    that kit be fine
    16 EXACT-SIZE METAL WASHERS
    (Steel won't expand when hot like nylon washers and cause the RRoD again)
    8 EXACT-SIZE SPRING WASHERS
    (These are needed to keep constant pressure through cycles of heating and cooling)
    boom!
    Sep 2008
    thanks people if i decided to just go and get a new 360 from argos lets say would it have the jasper chips set in and what would be chances of it getting rrod
    Jul 2008
    cmd
    Anything after Aug 2008 is pretty much unbreakable.
    Issues with overheating and RROD was solved.
    Think all the money MS spent on repairs and replacements made them see the light.
    Sep 2008
    cheers think i may just save time and messing about and get a later model then thanks for advice great forum
    Default xbox clamp help
    Quote Originally Posted by cgscott View Post
    bought this tried it and still getting the 3 rrod the bottom 2 lights and top left light.tried this 3 times with no joy ive loosen and tightened the screws waited for five mins to heat it up .waited an hour to cool down retightened and still the red lights.first time i done this any help apreciated.also why do you use metal washers and not nylon.
    Jul 2008
    cmd
    Try getting a heatgun and heating the solder up. Have a look round the 360 section.
    There is a thread with lots of stuff on using heatgun.
    Also youtube has a few tutorial videos.
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Or use a hairdryer. It gets hot enough to melt solder, well ours does And it worked. Our hair dryer is 1400 watts.
    Read the Rules here; they apply to EveryOne.
    __________________________________________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 motor powered by UsalS
    BALI7605's Avatar
    Brisbane QLD
    Default Bolts instead X-clamp
    Sorry for the silly question but as it seems those bolts stretching my xbox board a bit to far. Wandering if anyone else had similar experience.
    It is getting a bit bendi and it didn't cure my red lights.
    bali
    Member killersla's Avatar
    Merseyside
    Quote Originally Posted by blue eyes View Post
    If you can tell me what your secondary error code is i will tell you excatly what is wrong with your console.
    press and hold the sinc button on the console when it turned on and also press the eject button this will give you a series of 1234 flashing lights
    1 light = 1
    2 light = 2
    3 light = 3
    4 light = 0
    then go on to press the eject button 4 times in total still with the sinc button held in place this will give you a 4 digit code of flashing lights i.e 0102
    its funny on that ebay listing they state that it is a permenant fix
  13. #13
    Merseyside
    Quote Originally Posted by BALI7605 View Post
    bali
    the problem with that kit is i think the heads of the screws are a bit to big so when you put the board back into its case the centre is higher than the outsides.
    Did you have to push the board down so you could push the rf module back into place?
    I use 10mm counter sunk screws these fit perfect.
