Results 1 to 3 of 3
    Mar 2016
    South Africa
    Default Kuga 2.0TDCI Delphi DCM3.5
    Hi, sorry have a newbie question, is it possible to remove DTC P2263 permanently, so that it can't be set even though error exists. The vehicle runs fine for about 200km before this DTC appears and stays in limp mode until cleared with a scan tool. Vehicle is a 2014 Kuga 2.0TDCI with Delphi DCM3.5 PCM.
    Original bin attached.
    Thanks in advance
    Aug 2022
    България
    Don't forget the thanks and reputation button
  3. The Following User Says Thank You to PcmTuner For This Useful Post:
    Radic8R (11th August, 2022)
    Mar 2016
    South Africa
    Thank you. Is it possible to do a DPF+DTC delete as well as P2263 DTC delete on the original file attached ?
