Results 16 to 30 of 31
  1. #16
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    kiszka you mean it i see now
    the lesser you use your brain,
    the louder you use your mouth.
  2. #17
    May 2016
    BRAIN.EXE
    No soft no tool can invert pin to isk brother no one can helped ,but if you need to star car find good dump 95160 for uch and Virgin eps and uce motor and give acc2 ignition for auto learning uch to uce after this step learn key with code pin and all ok ��
  3. #18
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by tawaf111 View Post
    dont waste you time mate.
  4. #19
    May 2016
    BRAIN.EXE
    Do not waste time looking for something that will not help you to get out of the car problem, because the algorithms are related to each other in isk
  5. #20
    Sep 2022
    Quote Originally Posted by Ninjor s View Post
    Reported :-) hopefully you get the timeout you deserve
  6. #21
    Sep 2022
    Hahah funny when someone can't read a simple question, isn't helpful at all and then starts talking s%it
  7. #22
    Sep 2022
    For anyone else again my question: I saw in a another Forum that some guy was able to calculate the Isk from the Pin. I guess by just reversing the formula from the Renault Pin Extractor 2. My question is can someone calculate the Isk from the Pin BA ED F0 FE EA 95 for a Clio 3 with Keys?
  8. #23
    Sep 2022
    Here the proof
  9. #24
    May 2016
    BRAIN.EXE
    Pin=BA ED F0 FE EA 95 =isk 00 00 00 00 00 00 this your isk for this pin but maybe not working for learn key
  10. #25
    May 2016
    BRAIN.EXE
    if you need original isk read flash 64f7055f40 and post here for get real isk or do it virgin
  11. #26
    May 2016
    BRAIN.EXE
    It easy to star car without isk original but need read write virgin flash and all good
  12. #27
    Sep 2022
    The ISK= 00 00 00 00 00 00 is not my Pin BA ED F0 FE EA 95. Thank you for all your information but I'm asking here for someone who can calculate the isk from my Pin BA ED F0 FE EA 95. If you can't please just move on :-)
  13. #28
    May 2016
    BRAIN.EXE
    Default Renault ecu tool
    If anyone here you have renault ecu tool it can decrepted isk from flash ecu sim32 , this good news brother
  14. #29
    Sep 2022
    Quote Originally Posted by Italiandream View Post
    as you can see
  15. #30
    May 2016
    BRAIN.EXE
    But the isk in proof thread 7E 7A E3 A6 B5 ED get other pin code not 4D C6 F4 FD DB 6B !!!!???
