Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Sep 2022
    Default Renault Clio - PIN to ISK Code
    Hi everyone. I need help with my Isk Code. I have the Pin but in order to program the old keys I also need the Isk. Can someone please calculate the Isk code from it? It's a Renault Clio 3 with Keys - 2009 the Pin is BA ED F0 FE EA 95
    Thank you guys
    2B D5 DB E1 FD 75
    try this. my bitfibder keeps locking me out but the prog is good
    Sep 2022
    Quote Originally Posted by albertros View Post
    2B D5 DB E1 FD 75
    If you calculate your isk in the Clip Tool it's not my Pin. Thank you anyway.
    Dec 2014
    PL
    Quote Originally Posted by Italiandream View Post
    Maybe this one.
    5A CA B8 13 20 1D
    Sep 2022
    Quote Originally Posted by Mario6 View Post
    Maybe this one.
    5A CA B8 13 20 1D
    Did you put your ISK in the Renault Pin Extractor? Did you choose Johnson Controls Clio 3 under isk?
    Did you get the Pin BA ED F0 FE EA 95 as result?
    Nov 2021
    Netherland
    Vertaalresultaten
    Hello. If you can get the can clip. Can I help you
    Nov 2021
    Netherland
    hello, i can help you if you have a can clip.
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Mate what ecu you got in the vehicle s3000
    the lesser you use your brain,
    the louder you use your mouth.
    Sep 2022
    Quote Originally Posted by Ninjor s View Post
    Sim32 - Siemens
    Sep 2022
    Quote Originally Posted by lolo64 View Post
    I Don't have the can clip interface. I know with reprog it would be done in minutes...
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    post ecu eeprom
    Sep 2022
    Can someone else calculate the Isk from the Pin?
  13. #13
    Sep 2022
    post ecu eeprom
    You dont help me.
  14. #14
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    You dont help me.
    you need help and im telling what to do in order to help you,what is so hard to read eeprom and post here,i suggest you take this job and give to people who does this job.
  15. #15
    Sep 2022
    I'm asking to CALCULATE the ISK initial secret key from the Pin. You don't help me or others at all.
