Results 1 to 9 of 9
    Sep 2022
    Czech
    Question SIMTEC 71 Virgin
    Car OPEL Zafira A 1.8 16v 92kw (2004)
    Hi, when i do RESET ECU via IOTerminal must have to do some learn procedure or just swap ecu and turn ignition on?
    kiszka's Avatar
    Quote Originally Posted by MrQvik View Post
    Look for, such situations at Opel have been described many times here
    In google you can find it in 30 minutes and maybe even faster so many times it was written about it
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Sep 2022
    Czech
    Thanks for you reply, but still nothing resolved. Maybe if you knew that it would be better to post a link than write this comment.
    The world would be a better place, peace
    rafal's Avatar
    UK - PL
    don't be lazy.....................
    https://www.youtube.com/watch?v=TURWdqk-0gc
    need help
    now my goal is to buy xp-005
    who will help?
  5. The Following User Says Thank You to rafal For This Useful Post:
    MrQvik (7th October, 2022)
    Sep 2022
    Czech
    Thats fine but for CarProg and security pin solution -old ecu is burned (with eeprom). I made reset ecu to virgin via IOTerminal.
    rafal's Avatar
    UK - PL
    read pin from other unit ( immobox ) , adapt ecu to car by opcom - job done
    need help
    who will help?
  8. The Following User Says Thank You to rafal For This Useful Post:
  9. #7
    Sep 2022
    Czech
    Yes, I understand. I have carprog, opcom, and other. This is not a problem. The solution you give me is functional and verified. I know. But out of curiosity, I'm asking how it works in the case of resetting the ecu using the IOTerminal. I have no problem with not being able to get it working. But I'm interested in how it behaves in the second solution and since I don't have the car in garage, I want to prevent problems. that's why I'm just asking.
    Thanks for you
  10. #8
    Germany
    I think IO Terminal just reset the ecu, so that it is learnable. You can reset the ecu by yourself with pin of ecu with opcom. Only if ecu is reset you can adapt it again to another car. Thatīs it.
    Greets MR...
  11. The Following User Says Thank You to brobble For This Useful Post:
    MrQvik (10th October, 2022)
  12. #9
    Sep 2022
    Czech
    Quote Originally Posted by brobble View Post
    Greets MR...
    Thank you for your reply brobble
