Results 1 to 12 of 12
    roman_auto's Avatar
    Default Mazda3 airbag crash need to clear
    Hi all
    Mazda3 2008 , airbag by Bosch 0 285 001 961
    i tryied to clear with tacho reseter but no good it leave
    error B1342 ecu internal fault.
    cant someone clear it or have a good dump for this.
    Thanks in adcance
    try this
    roman_auto's Avatar
    Quote Originally Posted by tamvar View Post
    try this
    its the same what i have told u i clear it with tacho airbag.
    and tacho not good for this ecu.
    thsnks anyway
    bubbles69's Avatar
    Somehwere in the South East
    what is error B1342 sure its not fault in what has been replaced? are you sure that is crash code?
    kevfield's Avatar
    uk
    Test and report
    roman_auto's Avatar
    Quote Originally Posted by bubbles69 View Post
    B1324 - Ecu internal fault
    juozas10's Avatar
    LT
    Quote Originally Posted by roman_auto View Post
    Hi all
    Thanks in adcance
    Hi.
    Try this... crash data was cleared 100% clear, but other last foult are clearing by diagnostic plug ...
    Best regards.
    Sep 2012
    South Africa
    Default MAzda 3 Crash clear
    Could someone please help me clear crash data.
    Mazda 3 MPS
    Bosch
    BFB6 57K30
    F 01G 072 068
    95640
    I Thank you in advance
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try and report, if ok, press reputation+thanks.
    Best regards.
    Dragon
  10. The Following User Says Thank You to dragon100 For This Useful Post:
    deondti (15th June, 2016)
  11. #10
    morfej's Avatar
    A tested clear.
    Check if your bosch 40063 chip is ok.
    Br,
    morfej
  12. The Following 3 Users Say Thank You to morfej For This Useful Post:
    baygrozdan (12th June, 2020), deondti (15th June, 2016), PierreTheron1 (15th June, 2016)
  13. #11
    Sep 2012
    South Africa
    thanks morfej works 100%
  14. The Following User Says Thank You to deondti For This Useful Post:
  15. #12
    Sep 2015
    DK
    Hi mates,
    Can you help clear crash on
    Bosch
    BFB6 57K30
    F 01G 072 068
    95640
    Thanks!
