Results 1 to 15 of 17
    Apr 2015
    Sweden
    Default BMW X3 CAS4+ corrupted
    Hello Locksmith friends
    Have custemer with BMW X3 Suv Year 2016. CAS4+, saved D-flash and P-flash with VVDI Prog. Tried to make key, did not work. Tried put orginal D-flash and P-Flash back, not working. Was it encrypted? anyone?
    VIN WBAWZ5105H0S30055 . chip in CAS , 1N35H Regards J
    vialli's Avatar
    Aug 2018
    Romania
    What exactly could you not to do? In D-flash you have keys on positions 1,2 and 3, after you generate a new key on the following positions you don't have to write anything in CAS.
    You have to activate the key by holding it on the place with the reception antenna (there is a key symbol there) and press the start button
    Apr 2015
    Sweden
    Thank you for helping, customer is really pissed. I put cas back and try then? I could read out ISN from key. Did you check P and D-flash? did they look ok?
    I think I tried to downgrade P-flash with CGDI BMW, Mayby someone has a P-flash? I can write P-flash back? Regards J
    Apr 2015
    Sweden
    Think I need P-flash anyone.
    fred77's Avatar
    Jun 2019
    Solidarity with Ukraine
    fred77's Avatar
    Jun 2019
    cheap china tools were your trouble
    Hope somebody can help - but if not a replacement CAS comes next day with extra key ~£800
  7. The Following User Says Thank You to fred77 For This Useful Post:
    Weasel3 (11th October, 2022)
    Apr 2015
    Sweden
    Hello Fred, where do I get that from? Jakob
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    P-flash it's ok. so problem is in dflash or in your soldering.
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    baddaren (11th October, 2022)
  11. #9
    Apr 2015
    Sweden
    Thank you Lupu, Write P-Flash back second time. But this time I locked it when done writing, now works! Car starts, remote works and spare key works. Does the locking in VVDI Prog has anything to do with it?? Does P-Flash has to be Locked. Thank you for help and support. J
  12. The Following User Says Thank You to baddaren For This Useful Post:
    fuzz1 (12th October, 2022)
  13. #10
    newone's Avatar
    Oct 2016
    you do not have to write anything back,you read d-flash and then load it in a programmer to program key,thats it,after you present key to car to be activated like @viali wrote in post #2
  14. The Following User Says Thank You to newone For This Useful Post:
  15. #11
    Aug 2018
    Hi never kill cas4 with vvdi . More then 30 cars . Read backup option is very safety. the problem is between the chair and the table
  16. The Following 3 Users Say Thank You to vas100 For This Useful Post:
    baddaren (11th October, 2022), p1et (13th October, 2022), raf0468 (16th November, 2022)
  17. #12
    Apr 2015
    Sweden
    Thank you guys,I know I never have to write back p-Flash. But somehow I was tired, made a mistake and downgraded CAS4+, CAS corrupted. My mistake. Wrote it back and keys did not work on bench. Wrote P-Flash back again and locked it, everything worked. Does the locking with VVDI Prog have anything to do that it worked or was it my soldering? Used D-flash to make Key IN CGDI BMW. Happy ending. J
  18. #13
    Mar 2021
    this car has a long isn stored in the key+cas AND INSIDE THE DME. you need to input the long ISN when you modify a cas3+ or later CAS4 system!!
  19. #14
    p1et's Avatar
    Oct 2013
    Why even read P-Flash? Some users like to over complicate their job.
  20. #15
    Apr 2015
    Sweden
    If saving P-flashes for different CAS 4/CAS4+ cant you do it by obd. And if it does not work, just write the P-flash back? I am I right?
