Results 1 to 15 of 16
    Oct 2022
    Default KTag EDC17C74 not identifying/reading ECU
    Hello guys,
    i have a 2018 golf mk7.5 gtd dsg DGCA with a Bosch EDC17C74 (04L 907 309 R) (0 281 031 66) and i'm using Ktag 7.020 Red with SW V2.25. Unfortunately, Ktag cant read anything from this ECU. I use protocol and pinout 705 (boot pin with probe pen and bdm frame) and it doesen't even identify it, always ending up in a communication error.
    The ECU is still working like a charm in my car after opening.
    I already checked:
    • GPT Cable pinout is correct
    • D-SUB Cable pinout is correct
    • tried powering ECU via KTAG with 12V 1A, 12V 1,5A, 12V 3,0A
    • tried powering ECU with external 12V power supply
    • tried different pinout found in the internet by dimsport where CAN-HI and -LO go to pin 51 and 52
    When getting ID with Kess, it shows:
    HW Ver. 04L907309R
    Upg. SW 04L906026RK 7727
    Engine R4 2.0l TDI
    I also already tried reading it with a friends Ktag (also red, same versions) and its also not working / identifying.
    I already searched the whole internet for days and i'am despairing...
    Do you guys have another suggestions or things i could try to make it work?
    Greetings from germany!
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by mttlr View Post
    Hello guys,
    I already checked:
    HW Ver. 04L907309R
    Engine R4 2.0l TDI
    It turns out that your CAN is wrong there are 2 lines
    PLEASE PRESS THE " THANKS " BUTTON
  3. The Following User Says Thank You to gwiazdamb For This Useful Post:
    mkom82 (16th October, 2022)
    Oct 2022
    Thanks for replying, but i tried these two pinouts, the one where CAN goes to 30 and 31, and the one with 51 and 52.
    Both options are not working
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Check pick up voltage to 14V
    Boot connected
  6. The Following User Says Thank You to gwiazdamb For This Useful Post:
    mttlr (16th October, 2022)
    Oct 2022
    Yes, boot connected via probe pen, proper connection, measured resistance of pen to clamp via multimeter, I’ll try 14v tomorrow and will report
  8. #6
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Hello guys,
    I already checked:
    HW Ver. 04L907309R
    Engine R4 2.0l TDI
    Really you expect to read 2018 pass protected ecu with ktag clone? ( Maybe the very earliest version....)
  9. The Following User Says Thank You to Panathaole For This Useful Post:
    fuzz1 (17th October, 2022)
  10. #7
    Oct 2022
    Quote Originally Posted by Panathaole View Post
    So you say i shouldnt expect my shitty clone, being able to read this ecu? I already thought of this at some point, but i didn't want to admit it
  11. #8
    br556hre's Avatar
    Have you tried using protocol 675 (tc1797+no FLASH), or 739 (tc1791/tc1793+M58BW032FB) OR 748(tc1791/tc1793+no FLASH)?
    adding info pdf for all plugins
  12. The Following User Says Thank You to br556hre For This Useful Post:
    p38 (18th October, 2022)
  13. #9
    Dec 2019
    UK
    Buy pcmflash its a great tool for all VAG EDC17 and via OBD port, its good price
    Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
    “Yes,” reply the bytes. “Make us a double.”
  14. #10
    Oct 2022
    14,4V doesn‘t work either…
  15. #11
    Oct 2022
    I‘ll try when I’m home from work and will report
  16. #12
    Oct 2022
    Yeah, that’s what i‘m going to do when neither of this works
  17. #13
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by peechie View Post
    I confirm pcmflash very beaver prog without undressing it reads on the table
    and the price is decent
  18. #14
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    For one ecu i don't think is worth to buy an ori tool..... just give the ecu to a tuner, or in a shop with ori tool to read it, the cost should be very low.. (and the risk too....)
  19. #15
    Sep 2015
    There are much different EDC17C74 from VAG
    My 04L907309R H22 and H24 did work fine with KTag clone
    However 04L907309P could not been read with same tool and same wiring
