Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    BestElectrical's Avatar
    San Diego, CA, USA
    Default 2007 Volkswagen Passat immo pin
    Hello guys I am working on a 2007 VW passat 2.0t and i need to program a key for it. I am looking for a security access key code. where can i get that pin.? I called VW and they refused to give that information. Anybody knows where i can get it?
    PIN is in ECU and in comfort module (behind glove box) which comprise immobilizer.
    Read out dump of eeprom and post here.
    To adapt key you need also security bytes, so better read dump of comfort module, because it contain all 7 bytes.
    Which tool will you use to learn key?
    San Diego, CA, USA
    Can I use ross-tech VCDS?
    Ross-Tech: Home
    i will read the dump from the module and post it shortly
    heres the dump:
    VCDS will not adapt key to immo4 vehicle.
    I use VAG K+CAN (AVDI) commander with function "Key learning".
    Pls read additionally eeprom of ECU.
    Top Poster andresfn18's Avatar
    Mexico D.F.
    Default STERING LOCK
    YOU MOST READ THE MICRO IN THE STERING LOCK
    IT`A HC08
    San Diego, CA, USA
    here is the dump from the ecm...
    do i need to read from steering lock ecu?
    Login - 31487
    Component security bytes - 69 B1 81 A2 06 8E 06
    You can adapt key with commander, but not with VCDS i think.
    Just got the message from Abritus72 that CS bytes are incorrect. They suggest to read them through OBDII. So ignore them.
    The same situation with PIN extracted from dump using dump tool. It's also encrypted. Real PIN 03138. Pls check if ECU accepted one.
    San Diego, CA, USA
    the pin 3138 was accepted but im unable to learn the key for some reason, anybody knows a cheap tool that is able to do this stuff? i have Ross-Tech: Home tool
    Mexico D.F.
    Default FAZIT
    YOU NEED A FAZIT TRANSPONDER KEY, BUY IT IN THE AGENCY BY VIN CAR!!!
    IT`S THE CHIPER WAY!!
    To adapt key to vehicle you need to prepare dealer key. It means that you have to put 7 security bytes into Megamos 48 transponder prepared as TP23 (according JMA classification for VW). Then, knowing login, correct key learning procedure should be applied. It's impossible to make such key using VCDS. I use AVDI, Tango programmer and chips TP22-25. If you don't have such transponder, you can order key for your car according your VIN. It will be delivered with cut blade and ready to be adapted (CS inside). But correct tool for learning stage will be required. For the safety reason, it will be better if, before adaption, you save eeprom dump of comfort module, because there are Passats which die while key learning due to defective modules.
  13. #13
    San Diego, CA, USA
    Quote Originally Posted by Alex789 View Post
    Do you have the links where i can get all this right tools? thank you very much for helping
  14. #14
    www.Abritus72.com
    You need AVDI with VAG key learning function and order officially key by VIN. If you make business with VAG vehicles you'll get all your money back.
  15. #15
    ALEX789 PLZ I WANT TO ASK YOU ABOUT AVDI FOR ABRITUS 72 DO YOU HAVE THIS IS GOOD FOR PROGRAMATION THE KEY VAG FOR THE NEWS CAR A6 AND Q7
