Results 1 to 8 of 8
    Sep 2022
    Default Rate my remap! Fiat EDC15C7
    I started tuning and did my first remap.
    Fiat Stilo 1.9 jtd 59kw. I used winols, tried my best to not get a lot of smoke and I can say it isn't bad at all and I have more torque.
    Also did hardcut at 4500 rpm and have egr off.
    Mods - Cone air filter; egr delete, intercooler install.
    I wanted to ask if anyone can give suggestions to the remap, egr valve is completely deleted (physically and in ecu).
    Also wondered how can I implement launch control, I have searched online and only got results for VW gasoline engines by using Vag EDC Suite?
    Thank you all
    Sep 2022
    I forgot to mention, while starting up i always need to crank for 2-3 seconds which I think is a bit long... Is there a way to fix this issue by editing map file?
    shooting's Avatar
    WALES
    Quote Originally Posted by crnisin View Post
    Thank you all
    Need to post Original for comparison
    wbr
    Your tune:
    HW: 0281011552
    SW: 1037377120
    EDC15C7
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
    Sep 2022
    Original map
    shooting's Avatar
    WALES
    Original map
    Limited overall, even tho you are requesting high Mg/St
    Only 8 maps modified....
    Many untouched limiters etc..
    What are your concerns?
    wbr
    Sep 2022
    I lack power in top range, I couldn't find a mappack for my ecu so I found everything manually.
    What are the limiters you noticed?
    Also wondered how to have easier start, I don't know if I have to boost starting fuel pressure or what, it cranks for 2-3 seconds be it cold or hot...
    I found winols to be very tricky to find all maps I need
    shooting's Avatar
    WALES
    EDC15C7 is mostly switch driven maps.
    EGR off is by switch, see: "$71B54";"EGR Switch 257=ON 1=Off";"1x1"
    also "$71C94";"SVRL";"1x1"
    You'll need to get Damos for this ECU to make a good tune
    wbr
  8. The Following User Says Thank You to shooting For This Useful Post:
    crnisin (25th October, 2022)
    Sep 2022
    Thank you a lot, every suggestion is very helpful!
