Results 1 to 9 of 9
    Jan 2022
    Smile IMMO Sagem with with 93c46, Key 7935 + Remote Control, Old RENAULT MASTER 2001
    Hi members,
    i need help with programm EEprom chip 93c46 from Sagem Immobiliser 8200032776H 11011030-8A.
    Renault Master 2001-2002. I have one working key 7935 without remote, ID33 30F8F103FF7FE0000000C78FE3387E00. This key exist in Immo EEprom and active (now in e2p active only one key). Also i have 7935 key with remote control from another Renault Master: ID33 3000F01F077EE0000E00C771FCC08103. This key i want add to EEprom. Some solution?
    EEprom data i was read with Carprog programmer after desoldering from IMMO Box. Autel, SVDI cannot read eeprom via OBD. Exist programm for read/write IMMO Eeprom without desoldering or any another way to programm new key with remote withouth desoldering?
    Thanks for advice.
    Apr 2021
    Belarus
    It is impossible to program a donor key together with the original one. You can program a donor key with remote control and make a copy of the transponder. But programming the used key is a complicated procedure and requires brain work than the presence of superdevices.
    Jan 2022
    I not need to reprogramm chip U9280M in donor key. I need only add to IMMO EEprom data ID from donor key: 3000F01F077EE0000E00C771FCC08103. EEprom data is too small:
    1d 24 ff ff ff ff a9 90 ad 9f 9f a9 fa ad b4 48
    d7 ff 0f 92 dd 0f 9f 36 ad 00 00 1a 00 00 d8 24
    00 00 27 03 11 76 10 01 08 30 06 41 23 02 ff 02
    ff ff ff ff ff ff ff ff ff ff ff ff ff ff 16 fd
    I think someone can decode this data for edit/add key information. As i know in this data also coded PIN information and ID from working key: 30F8F103FF7FE0000000C78FE3387E00. Autel and other can decode from this data ID existing key. But i need revese process, write another ID 3000F01F077EE0000E00C771FCC08103 to this data.
    Thanks.
    Apr 2021
    Belarus
    I perfectly understand what you need. You didn't read my post carefully. I can recalculate the ID into immodata a little later.
    Jan 2022
    Thanks a lot.
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by Sansanyc View Post
    Thanks.
    it is not possible to add a key from another car and make the old original key work
    such possibility does not exist without refreshing the key and the key cannot be refreshed
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Apr 2021
    Belarus
    30F8...7E00 immodata 36 9F 00 AD 1A
    3000...8103 immodata 70 99 08 D5 24
  8. The Following 2 Users Say Thank You to meser75 For This Useful Post:
    miroopel (1st November, 2022), Sansanyc (2nd November, 2022)
  9. #8
    Jan 2022
    Thanks a lot!!
  10. #9
    Apr 2021
    Belarus
    Thanks a lot!!
    If you liked someone's answer, here it's customary to press the thanks button on that post.
  11. The Following User Says Thank You to meser75 For This Useful Post:
