Results 1 to 10 of 10
    Mar 2013
    Default DM800HD not getting picture
    Thought my DM800HD dead sometime ago as there was no power.
    so left it in garage, yesterday, thought of trying with another power supply, and it was powering up.
    so the problem was power supply. Now I don't see my network channles, I can see my free channels fine.
    network channels I see blank screen with subtitles and no audio.
    This is was working with all channels before. can somebody help me what could be the problem?
    Feb 2013
    Quote Originally Posted by dark5tar View Post
    was it working before you stored it away in the garage?
    Did you do any updating of the bouquet safter you powered it up using the new power supply?
    Aug 2013
    Check ur keys and scce if it's there.
    Mar 2013
    Quote Originally Posted by shidevil View Post
    what is scce? It was working perfect before it went off. I have manually scanned all the channels, no use,
    Re -edited my cccfg file but no use.
    thought may be box is not connecting to internet, checked all the network stats, they were going thru fine.
    But tried mytube, if i click on any clips , it fails with green screen
    Feb 2013
    Pls read this Sticky and u will come up to s***d on the various concepts Newbies from SG - Read here first
    Mar 2013
    Quote Originally Posted by pirsquared8 View Post
    I was having blackhole image before now after reflash this is enigma image.
    But i don't see any channels now.
    It says
    "service unavilable check tuner configuration"
    how to tune my channels with this new image now.
    when i saw provider , it shows BPL,DEMANDTV, STARTHUB
    none of these were in my list previously, it used to be bSkyb
    how do i tune to that provider now?
    Thanks for your help
    Regards
    Feb 2013
    Did you read the sticky that I mentioned?
    Mar 2013
    yes, but I haven't backed up..
    is there a way I can configure my tuner, as I went into settings
    setup--service searching-- tuner configuration shows tuner A: Alps BSBE2 (not configured),, when i click on this i get another screen with " configuration mode == nothing connected"
    this is enigma v3.0 image
    please help me
    DK Veteran SGDVB's Avatar
    Dec 2009
    It says
    Regards
    Think you are on the wrong section. Here we are talking abt cable tv, not sat tv.
    Jan 2013
    It says
    Regards
    A ghost might have swapped ur set!! Just kidding mate... Just a nuisance kidding around here.
