Page 24 of 65 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 967
Thread: RCD 510 codes.
  1. #346
    Member alyvo's Avatar
    Earth
    Hi ! Please i need code for this blaupunkt.
    Thanks in advace !!
    Audi A6 Quattro
  2. #347
    May 2018
    you can only unlock rcd?
  3. #348
    levisdj's Avatar
    EcuLand
    Hi, please verify if first two digits are 03 on this 510 radio please...
    Another thing, after putting FF dump into radio at startup I got 127 remains... now I have to put original back to get unlimited tries, right? thanks
    F8 XOR F8 is 0
    32 XOR 03 is 31 ...
  4. #349
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by levisdj View Post
    F8 XOR F8 is 0
    32 XOR 03 is 31 ...
    first two are 01xx
  5. The Following 3 Users Say Thank You to richiebb For This Useful Post:
    audiopoint (17th May, 2018), Decode Ghost (17th May, 2018), levisdj (17th May, 2018)
  6. #350
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    I get 01xx
  7. The Following 3 Users Say Thank You to audiopoint For This Useful Post:
    Decode Ghost (17th May, 2018), levisdj (17th May, 2018), richiebb (17th May, 2018)
  8. #351
    levisdj's Avatar
    EcuLand
    So no need to rewrite original dump ? just put it back and try ?
  9. #352
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Yes, write original dump, find last two digit 0100, 0101, 0102....0199.................
  10. The Following 3 Users Say Thank You to nelutzul40 For This Useful Post:
  11. #353
    levisdj's Avatar
    EcuLand
    Okay ... will try and report... thanks guys!
  12. #354
    levisdj's Avatar
    EcuLand
    With the original file I get only 2 attempts ... !! should I write the other file ??????
  13. #355
    levisdj's Avatar
    EcuLand
    Not working guys, I put the FF file again... I got 127 remains.... after digiting one code that was wrong I got only 1 attempt left... what am I doing wrong ???
  14. #356
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Read NEC with this simle programmer, post file and get FULL code.
    For 01xx after try two code, need to rerwrite original dump.
  15. The Following User Says Thank You to nelutzul40 For This Useful Post:
    levisdj (18th May, 2018)
  16. #357
    levisdj's Avatar
    EcuLand
    Allright,I will look into that... thanks!
  17. #358
    May 2018
    Hi guys, can I please get a code for my stereo?
  18. #359
    levisdj's Avatar
    EcuLand
    Hi guys... I found the RNS510 cable adapter from carprog... but some warnings say about SW number into damaging the unit... how do I figure that out ? and seeing the diagram I should connect 3 wires, but on this adapter I have five wires... is someone can bring some light into this ...thanks
  19. #360
    Hello
    Please can you help me with a radio code for RCD 510 BLAUPUNKT 1K0035195AA 7647211360. I attached eeprom + nec.
    Thanks in advanced.
