please need code for my radio rcd510
RCD510
VWZ1Z3I4241341 3C8035 195
815 7 647 239 360
Thanks in advance
RCD510
815 7 647 239 360
Thanks in advance
Thank you very much.
Wait "einet" member who successfully find code for rcd510....
your code are 05**
send PM
einet
hi, einet
I have an RCD510 and need its code.
s/n is
VWZ1Z3H3382333
3C8 035 195
815 7 647 239 360
I sent you a PM.
I just try to repair it,
using VWZ1Z3H3382333 's main board and
VWZ1Z3H3374763 's EEPROM and LCD module.
I try to login using VWZ1Z3H3374763 's PIN code(195X) but fail.
so I need VWZ1Z3H3382333 's pin code and try if I can login.
thanks for your help.
Hello
you are registeratet from the laste year and have only
9 post?
I pute a rule for codes "no more for free".
.....code(195X) but fail.....when you have a code you must lost the code!
Your code? when yes, this doesn?t never is your code!
you code bins "0x7x"
einet
after several days, I had tried from 0000~1999.
unfortunately, I can't get the code.
my RCD510 is
VWZ1Z3H3374763 's EEPROM(ST95128) and LCD module.
VWZ1Z3H3382333 my friend's machine
VWZ1Z3H3374763 my broken machine,I can't find who can repair it in Taiwan,so it become parts....
At first,
I help my friend to modify his RCD510 and make it can accept AV-input RGB-input. We want to add TV and GPS to RCD510.
after the job done, we want to test it but ......
my friend forget his code,he tell me that he remember some numbers in the code. I try the possible code that he told me.
but all incorrect.
I try to read eeprom and save it.
when machine locked , I can write the original dump into eeprom and can try again in short time.
after I write original dump into 95128 eeprom, RCD510 start blinking. I check the dump, it is EMPTY.
we lost the original eeprom data.
so I using my broken RCD510's eeprom(have code) and swap the empty one. It can work but can't login by known code.
I think maybe the original code (VWZ1Z3H3382333's) can login. we don't have the code for VWZ1Z3H3382333 to try if it is true.
after I tried from 0000~1999,
I think VWZ1Z3H3382333's code can't login also,
although I don't have its surely code.
sorry for my bad Engllish and that is why I only have 9 posts.
not sure if im doing this right but i have a renault laguna radio thats needa the code can anyone help . . . . . . .
serial no RN279F1004663
TOQ468
Any help would be great !!!
Hi guys,
I am from Singapore and currently, I am am thinking of taking out the RCD 510 and install into my fren's ride.
However, I do not have the code and when I checked with the dealer, they didn't have it either... ?????
Sorry for asking this noobs question, how did you guys take out the unit and test the code one by one??? do you connect to external source???
As of now, I guess I have to try to have 20 posts and hopefully, EINET can assist me...
Sorry guys....
Another noob question, how do you guys take out the RCD 510 unit?
I try to pry open but ..... in the process broke a small edge of the panel.
Is there any websites I can find?? Try to google but to no avail.
Maybe I didn't hit the right words.....
Thanks!!!!!
Hello Einet,
I have this RCD510:
815 7 647 239 360
VWZ1Z3H3246XXX
3C8 035 195
Can you tell me the code???
The XXX I will send you oon PM.
Thank you very very much
VWZ1Z3I5238417
815 7 647 241 360
3C8 035 190
