Results 1 to 5 of 5
    Mar 2017
    Question Visteon VP6C3F, more attempts to enter code?
    I have a Ford Focus radio, Visteon part no V9C3F-18C939-AA, serial *AHK031111*. I have been using the attached dump to repair it a few times (code 4630).
    The issue I have is that this dump only allows 3 attempts to enter the code, if you fail the three times, it shows "ERR CODE LOCK" and wont let you enter any more codes. I tried waiting 45 minutes, holding 5, 6, 6+1, etc while turning on but it never gives me one last chance to enter the code, I always end up having to desolder the chip and putting the attached dump to fix.
    Is there a way to modify the dump to get more attempts to enter the code or at least one last try so I wont have to desolder and reprogram the chip every time it gets locked? I think the default behavior from the factory gives you more than 3 attempts.
    Raimax's Avatar
    Nov 2013
    LT
    This dump is not yours
    If you don't like it * close your eyes
    --- Geros dienos ! ---
    Mar 2017
    Quote Originally Posted by Raimax View Post
    Who said it was mine and why does it matter? It's a dump that was posted on this forums, I've been using it, like I said.
    Raimax's Avatar
    Nov 2013
    LT
    Because dumps from other radios are not always suitable
    gabriel pablo's Avatar
    Mar 2019
    argentina
    hello friend, to get out of the code lock error, hold down memory 6 for 20 seconds, then enter the code
    your code is
    7044
