Results 1 to 15 of 15
    Jun 2009
    Default immo off toyota corolla 97
    i have a toyouta corolla age 97 with fujitsou ecu number
    89661-1a760
    211000-5200
    4e-fe
    i have lost the keys.
    i have to buy a new car with empty chip inside?
    how i will reset ecu keys ? from module of immobilizer?
    what eprom i have to read to post it? virgin file?
    thanks to people that will help me................
    gokey's Avatar
    can you post a picture to ecus?
    DK Veteran agabna's Avatar
    hello
    u have to send more detail for the ic
    atmel 24c02 our 2502,93c56 and the engine 1.3 our 1.8
    manual our at
    to send u the right file
    Jun 2009
    Default help
    here are the foto for ecu im*o box..
    i have read memory 93lc66 of im*o box 89780-12060
    it use texas 4c,tpx1
    can someone find the key from file to program a empty tranpoder chip?
    or
    i have to virgin memory of memory and what key data i have to use in key?
    gokey's Avatar
    you read 93c66 from immobox ?
    Jun 2009
    yes off course i read it and is inside rar file.
    i see that the are programming 3 keys in immo ,i believe i am not sure.
    i find that transpoder chip is texas 4c, tpxi
    Szczecin;Poland
    Try ( You can use EH2 electronic key) in tiris format:
    7E D0 3A CE 01 00 00 00 00 E3 FF 7E 00 00
    Jun 2009
    i found key silca TOY46REH2 Ι would like to ask why the data on key change:
    7E D0 3A CE 01 00 00 00 00 (E3 FF 7E 00) because is tiris format?
    EPROM FILE LOOKS 3 KEYS LIKE:
    7E D0 3A CE 01 00 00 00 00 D0 3A CE 01 00 00 00 00
    7E 4D 3A CE 01 00 00 00 00 4D 3A CE 01 00 00 00 00
    7E 72 BC AD 01 00 00 00 00 72 BC AD 01 00 00 00 00
    this is hex format?
    Jun 2009
    thanks key worked
    7E D0 3A CE 01 00 00 00 00 E3 FF 7E 00 00 00
    is a program to calculate key data from memory data?
    I have the same car with lost all keys.
    Can you help me with the keycode from this dump?
    Or make the dump for 1 key with
    Tiris 7E 04 FC 3C 09 00 00 00 00 55 97 7E 00 00 and
    Read 7E 20 3F 3C 90 00 00 00 00 AA E9 7E 00 00 Typ 4C tpx1.
    Thanks.
    gokey's Avatar
    7E 6F A4 80 76 00 00 00 00 54 90 7E 00 00
    TIRIS : 7E F6 25 01 6E 00 00 00 00 2A 09 7E 00 00
    for dump toyota_ 93lc66.rar
    gokey's Avatar
    or dump for transponder logic
  13. #13
    Thanks gokey but the dump is not ok.
  14. #14
    melbourne, australia
    could someone explain to me where these dumps come from?
  15. #15
    Hello i have the same ecu but i need to replaced because is broken.
    how can i clone the immo data to other (used)?
    thnx
