Results 1 to 4 of 4
    Dec 2017
    turkey
    Default a3 cluster warning light
    Hello, my vehicle is audi a3 2007 1.6 bse engine.
    Indicator warning lights are on in my vehicle.
    These:
    ABS, ESP and Handbrake led blink
    Oil, oil sensor, coolant, brake pad, washer fulid...
    Cluster No: 8P0920931A 0560
    I checked all related components via vcds. Canbus reads all components correctly.
    I can test the indicator via VCDS, there is a ROM error on the immobilizer. 16346...
    I have read with the devices I have, but I have not succeeded.
    Devices I have:
    1. Odyssey
    2.VCP
    3.VCDS
    4.KKL
    5.Ch341 eeprom.
    I think the problem is with the indicator. I can share 24c32 smd read result. Do you think the problem is software or hardware? Should I change the indicator?
    I can accept flash file for Odis.
    Thank you.
    Aug 2019
    Romania
    can you post an autoscan of this car, you should have some fault somewhere?
    Press Thanks Button and Reput if i helped !
    Dec 2017
    turkey
    VCDS scan file and 8p0920931A 24c32 eeprom file
    Dec 2017
    turkey
