Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Nov 2022
    Germany
    Hello i buy a new EEPROM and i write a new file from Ricked, and again i have still P0602 (Bad Programing). The files from EEPROM again change the value.
  2. #17
    ricked's Avatar
    Apr 2016
    Europe
    what did you "repair" in speedometer?, because data in new file is not the same as what i did give you!
  3. The Following User Says Thank You to ricked For This Useful Post:
    MartinSUK (28th November, 2022)
  4. #18
    Nov 2022
    Germany
    Quote Originally Posted by ricked View Post
    The previous owner must have done something to it. But what i dont know...
  5. #19
    Nov 2022
    Germany
    Hello. Im reprogram new EEPROM and now is ok speedometer is working! But i now problem with ignition. Car doesn't starting with key, immo is ok. Nothing happens when i turn a key just silence. the car starts when the key is turned to the ignition position and the relay is shorted manually. I checked the relay it's fine.
