Servando have keygen for Paccar Esa, or now not???
the key for esa tool is only for dealers kenworth, do you need eportal access and then the program load the licence there.
but for access to eportal you need ID and Password, which only the worker of kenworth have
Hello check this theard http://www.digital-kaos.co.uk/forums...erbilt-177455/
u can down load hear
i know some peaple at dealer if i could get them what filles should i have them coppy also i have look at one unit about 1 year ago and it will let u export the lic
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
does this paccar software work with cummins ?
HUM PACCAR 2011 IS DAFF MOTOR
I WORK FOR PETERBILT IS NOT SAME PROGRAM
I NEED THE NEW PROGRAM FOR PACCAR MOTOR DAFF
Paccar used cummins engine called px6 and px8. Cummins serial # and cummins software "insite" to trouble shoot. (yes cummins engine with different paint.) Kenworth and Peterbuilt have there own diagnostics, for cab and instrimintation called ESA. 2010 Paccar realeased there own engine called MX this engine requires the Davie diagnostic software with a matched communicator addaptor. The MX will not work with other software or comunicators. It is European engine that paccar "bought" from truck company Daf. from what i know they use the davie software as well??
