Still any solutions for ESA?
anybody trying to get a solution to esa
__________________
IF I WAS OF ANY HELP TO YOU PLEASE DON'T FORGET THE SCALES AND THANK'S BUTTON !!!!!
Elfer (10th May, 2013)
This program is useless to me. I would check and make sure it can change the parameters you are looking to change... before putting alot of effort into getting it. There is no real access to the motor... speed limits... and govenor settings and the like. That may change later, but for governor settings... progressive shifting setup... it is useless.
i need it for the body modules
__________________
Any update for a fix or crack or something please?
to activate davie tool you need the wks code to be full in software
hey fellow Dk friends Ive been playing around with the paccar esa program. I have found out the the Insite key generator floating around out there will make a key for you but there are also other things you needs so if anyone out there knows how to mess with stuff like this there would be a a good start.It will create you a key with the insite key under basic but from there somone has to be able to reprogram the key to make it work with the rest of esa. SO I just want to put that info out there for fellow DK friends
Remember the only Dumb Question Is the One Never Asked ! Always Make Sure To Thank The Person Who Helps You Here At Dk !!!!!!!!!!
