Results 1 to 15 of 27
    Member moztas's Avatar
    Default Megane 2 Dashboard Problem
    I have a Megane 2 dashboard which is not working and only immobilizer led is lits. I could get the eprom dump (93C56) from dashboard. Can someone help me is there is problem on attached dump.
    By the way, I have checked the voltage regulator and crystal (4 MHz) on dashboard. Regulator's 5 VDC output and microprossesor crystal is working.
    Thanks in advance!
    BR,
    moztas
  2. The Following 2 Users Say Thank You to moztas For This Useful Post:
    pintobraz (23rd October, 2017), salimscan (19th October, 2020)
  3. #2
    Does anyone have a virgin Megane 2 dash eprom (93C56) dump to compare with mine or the test? It would be great if someone help me!
    Your file is corrupted. again correctly read.
    I will send you - with a similar car.
    regards
    I have one cluster of megane 2, but I dont know what model.
    Tell me please reference of cluster and all information you can so i could see if mine cluster is the same. If it is of course i will read eeprom for you......
    I found quickly.
    regards
    bricolo's Avatar
    france
    i dont have a virgin dump but i've read a dash , if
    it can help you
    Quote Originally Posted by elektro128 View Post
    regards
    Yes you re right! I checked the eprom again and realised file is corrupted. I attached again.
    Quote Originally Posted by bricolo View Post
    it can help you
    thanks bur it is scenic 2 dash eprom, right? I need megane 2
  10. #9
    I found quickly.
    regards
    Many thanks for the dump. I'm not experienced about cars and I have questions regarding this dump. If I use your dump;
    -Will odometer value be change? My cars was 35.000 km
    -Will there be a problem for immbobilizer system?
    Thanks and Best Regards
    moztas
  11. #10
    Quote Originally Posted by GolfmkI View Post
    Thank you for reply GolfmkI.
    There are two stcikers on dash. One of them is on the back: #MRX085389# and on right side PDAC085389. I dont know if they are serial or model number.
    Anyway I took I photo, please check it.
  12. #11
    Mine is KDAH1149010
    REF RENAULT 8200408798
    It appears not be the same
    Sorry
  13. #12
    Mine is KDAH1149010
    Sorry
    Thank you anyway! Have a good day.
  14. #13
    I found quickly.
    regards
    elektro128, I used your dump to megane dash and it worked well. Thanks. But mileage is now about 180.000 can you please help to decrease km to 65.000.
    BR
    moztas
  15. #14
    Jun 2009
    here is your dump with 65000 km, good luck
  16. #15
    Many thanks aeroyas. I will try and report.
