VAG-COM/VCDS EVERYTHING - Page 337
Page 337 of 843 FirstFirst ... 237287327332333334335336337338339340341342347387437837 ... LastLast
Results 5,041 to 5,055 of 12634
  1. #5041
    Feb 2017
    It's supposed to be faster than the HEX CAN version and it has a removable cable.
    Also, they have removed the labeling from the micro-controller..
    If you look closely you can read the ARM letters at the top.. And ST letters at the bottom. Well, here it is..
    How am I sure that is it F4 and not F1 or F3? Because it is the size of F4, and F1 or F3 are smaller.
    And for the voltage regulator - I will test it soon. Thanks for the help! Also, I've already received the refund.
  2. #5042
    @ireun
    I see
    Type: Ross-Tech HEX-USB
    but should be
    Type: HEX V2
    Cheap chinese interface in new case...
    https://www.youtube.com/watch?v=1OkpJe8ySUc&t=48
  3. #5043
    Feb 2017
    @tk500
    Exactly, but the chip is really different, so maybe it's really supposed to be faster, they just used old dump.. To be honest I don't know.
    Atmega162:
    • 8-bit
    • 16 Mhz clock speed
    • 16K Bytes of In-System Self-programmable Flash program memory
    1K Bytes Internal SRAM
    ARM STM F4:
    • 32-bit
    • Maximum clock rate of 84 / 168 / 180 MHz
    • Up to 1 Mbyte of Flash memory
    • Up to 192+4 Kbytes of SRAM including 64-Kbyte of CCM (core coupled memory) dataRAM
    To be honest, this chip is way more powerful than old Atmega..
  4. #5044
    MCU is too powerful
    So it does not work.
  5. The Following User Says Thank You to tk500 For This Useful Post:
    fantomel (12th July, 2017)
  6. #5045
    Jul 2017
    Sorry for my first post as a "lamer"question :
    VCDS VAG-COM 12.12.0 always used with no ethernet connection and retro-date (01-oct-2013 as per manual)
    I was resetting flap motor on my AUDI , it comes with "this function requires a licensed interface" message
    Reinstalled VCDS on a different fresh computer , same error
    Is it the cable circuit corrupted rather than software/pc ??
    Is there a procedure to restore to previous working state ?
    This is the interface :
    Thank you very much for any answer you can give me.
    regards
  7. #5046
    You can repair it with kolimer files and have 17.1.3 version
  8. #5047
    Jul 2017
    just two silly questions:
    My working 12.12.0 has never been connected to internet while VCDS was running or USB cable connected :
    Why it has become unlicensed itself ???
    If cabled was voided someway,(atmega/flash modified) it was been done via USB , why it is not possible to do the same via USB to restore ??
  9. #5048
    Jul 2017
    Please , to make the long story short , I don't understand the complete procedure for Kolimer's 17.1.3 :
    Into the archive we have :
    epromavr.bin
    epromavr.hex
    eepromftdi.bin
    which one(s) has to be used and which programming software has to be used for ?
    flash...044.bin
    flash...044.hex
    flash...046.bin
    flash...046.hex
    ftdi_ft_prog.xml
    ftdi_mprog.ept
    which way have to be used ??
    VAGCOM_HWType.exe cannot be used as FTD2XX.DLL is missing : where to find this library ? which version ?
    As you see there is a lack of informations , yes I well understand who provides these tools is an experienced programmer/engineer but newbie cannot go ahead by try and try (with a possible HW failure)
    The only tutorial found, refers to another procedure (vidpidfix plus ponyprog)
    Please, can anybody explain to community in just few rows the right procedure and software used ?
    Thank you very very much
    All work very appreciated.
  10. #5049
    Jul 2017
    Anyone got ols loader for winols 1.5?
  11. #5050
    Jul 2017
    Quote Originally Posted by ireun View Post
    ...How am I sure that is it F4 and not F1 or F3? Because it is the size of F4, and F1 or F3 are smaller.
    Perhaps this chip STM32F072 in LQFP64 package, it?s easier and cheaper, fully suitable for this device. What driver is used for this cable? This is emulation of FT232 functions on the CPU or substitution at the software level?
  12. The Following User Says Thank You to BASi77 For This Useful Post:
    ireun (15th July, 2017)
  13. #5051
    Feb 2017
    Quote Originally Posted by BASi77 View Post
    Perhaps this chip STM32F072 in LQFP64 package, it’s easier and cheaper, fully suitable for this device. What driver is used for this cable? This is emulation of FT232 functions on the CPU or substitution at the software level?
    I can't see any chip on this PCB that would do that. In terms of driver.. The VCDS setup .exe is signed by Ross-Tech, also, VID is the same as for the FT chip.. So probably just a substitution..
  14. #5052
    Friends I have a big doubt. I have been following this thread as much as I can since first post and I have learned to repair a cable. I have repaired a pair of mine in the past with great sucess. But still I have a big doubt, why sometimes cables get broken (interface not found port not ready usb port not recognized) sometimes after repair an interface? In fact even usb port is not recognizing FTDI IC in cable, why this happends? I have try changing FTDI IC without luck at all? I am using an isolated WinXP 32bit session without any network connection at all and ICs inside cable have been repaired/reflashed properly, according to info posted here. Interface can work some minutes, days inclusive weeks without any issue and a day it simple stop working and computer can not recognize it usb port. Then anyone can enlight me to know how to correct this hardware issue or how to improve a clone cable to avoid this issue?
  15. #5053
    Jul 2017
    Quote Originally Posted by eliotroyano View Post
    It seems the same issue I was talking about on this page.....
    Cable becomes unlicensed or unusable without connecting PC to internet....... why does it happen ??
  16. #5054
    Jul 2017
    .. In terms of driver.. The VCDS setup .exe is signed by Ross-Tech, .. So probably just a substitution..
    Could you copy the installation CD from the cable "HEX-V2" on ge.tt and post the link.
  17. #5055
    Feb 2017
    Sure, there was also an archive on the CD, that had this file in it, but it was corrupted... So only the .exe http://www91.zippyshare.com/v/Jm3ddt4j/file.html
    Zippy > ge.tt
  18. The Following User Says Thank You to ireun For This Useful Post:
    BASi77 (14th July, 2017)
