But from where we can get new eerom for version 17.8.1 ? For 17.1 3 is eeprom 1.96
What is for 17.8.1 ?
Kolimer you also share eeprom for version 17.8.0 ?
Ok i am waiting with good instruction.
Universal crack for all languages or for each its own? Maybe some beta version of crack is ready for testing?
As I promised
http://ge.tt/4myEM4m2
https://www.sendspace.com/file/5euqp9
http://www.filehosting.org/file/deta...SLoader_v1.zip
http://www9.zippyshare.com/v/mAIYEKvT/file.html
Read Info.pdf
Write FLASH and EEPROM from archive, install latest vcds of any language of your choice, copy VCDSLoader and enjoy.
For me it's working WinXP, Win7, Win10 32/64.
2xded (6th August, 2017), alin 151 (5th August, 2017), BASi77 (5th August, 2017), bibkare (7th August, 2017), cocutanu (6th August, 2017), Domi (8th August, 2017), EpicFail78 (7th August, 2017), fantomel (5th August, 2017), flavitm (7th August, 2017), jakuza (15th August, 2017), kowalwalcz (6th August, 2017), miltas (17th December, 2017), miouser (30th April, 2018), nagyelek1982 (6th August, 2017), naprawa5 (31st August, 2017), pepeEL (7th August, 2017), pike (8th August, 2017), plavac65 (5th August, 2017), PSAcars (6th August, 2017), Qwarz (5th August, 2017), sania387 (8th August, 2017), stonecoldro (5th August, 2017), vaicekas (12th August, 2017)
Hello kolimer. This is only for ft/rl or I can use it on bl/bm/bq
Everything works perfectly. Thanks again.
Attachment 467328 Attachment 467329 Attachment 467330
Attachment 467331 Attachment 467332
Thank you @kolimer again for the brilliant work!
A small note: before I flashed 17.1.3 (the old version), the HW detect tool worked for me and correctly detected my HW_46 interface. After flashing, it is not able to detect it anymore and exists with "no response". Same thing happened when I upgraded to 17.8. The tools works of course on cars perfectly.
Any ideas if the new firmware or eeproms might cause the HW detect tool to not work anymore? Or maybe it is just a coincidence![]()
@PSAcars did not test, have only RL inteface. Try it yourself & report
@stonecoldro HW detection tool should work
ZIP archive MD5 is d49793019c0cadb657e5cc720dd1a310, virus detection is false positive.
fantomel (7th August, 2017), jan4 (20th May, 2018), kowalwalcz (6th August, 2017), mkii (6th August, 2017)
Thank you so much....
i updated 3 cables, without any issues...
Everything works perfectly for RL interface.
For BM, after write ...interface not found.
With VAGCOM_EEWrite after write, version is 1.59 and firmware update required!
After update,...Interface not found! with Vcds loader.
With vcds 17.1.3 craked..License Valid.
Thank you @kolimer
Hello
i have tried this pcb --- First Works Perfect with 17.1.3 But After some days get some Problems with vid403 pid000
but no internet--- i have Had another driver in this laptop ftdi --- maybe get problems from this
anyone knows this pcb and know To flash????
what make wrong ?
after flash HW 0x46 cable partialy working, CAN not work
if I helped You, press the button THANKS
