Please delete the picture with the serial number.
Sent from my D6603 using Tapatalk
is it possible to upgarde the firmware in China clone cbales?
I have a 8.05, 10.6 and a 12.12 .....
Canīt really make out whether it is possible or not when reading this thread ?!?!?!?!?
best regards,
can ok + coding a3 8p 2007
Announcing VCDSLoader_v2 with fixed reported issues
http://ge.tt/3q0nKAm2
https://www.sendspace.com/file/6dllpa
http://www115.zippyshare.com/v/mLxhZ1oB/file.html
Write FLASH and EEPROM from archive or use VAGCOM_EEWrite if you have correct bootloader, install latest vcds of any language of your choice, copy VCDSLoader and enjoy.
Fixed VAGCOM_EEWrite for HW 0x44 and failed update from vcds
Fixed FTDI BM/BL
34260551 (14th August, 2017), alin 151 (16th August, 2017), apath_e (1st June, 2019), apv (15th August, 2017), BASi77 (15th August, 2017), bibkare (15th August, 2017), Cacok (16th August, 2017), ChopstiX (16th August, 2017), cocutanu (16th August, 2017), d0di (1st January, 2018), electrohicham (23rd November, 2017), fantomel (14th August, 2017), flavyus1987 (15th August, 2017), ghicicine (1st December, 2017), ivica21 (14th August, 2017), jakuza (16th August, 2017), jos68 (14th August, 2017), mamuko (15th August, 2017), miouser (30th April, 2018), nagyelek1982 (17th August, 2017), neurok (20th August, 2017), offline (9th September, 2017), paro44 (17th August, 2017), Qwarz (15th August, 2017), Tor999 (6th June, 2022), tr3ce13 (29th August, 2017), Tyu2000 (14th August, 2017), vaicekas (20th August, 2017), Wene001 (30th December, 2017), xoom (25th August, 2017), Yuri_L777 (1st November, 2017)
Thank you for your work.
Thank you Kolimer for your amazing work, i tested now loader V2 and it doesn't start on win XP, on win 7 works excellent
All works fine on BM chipset.updated directly from usb conection.works on w7 64bit and XP 32 bit.
I does work with BL interface and Windows XP 32-bits. It happend that program didn't want to open up but after replacing loader for new one, everything works OK.
Tested with VCDS 17.8.0 EN
apv (19th August, 2017)
I have a cabel VCDS (china clone) as show on photo. This cabel have pinout inside but i dont know what is what. Pinout is not described. Can you help me how i must connect it to USBasp programmer ?20170816_192649.jpg
you have hardware 44, pinout from left to right 1st picture is : 5V+ GND RST SKC MISO MOSI.
my advice connect programmer on all pins but not 5V and power interface on obd by 12V. Like this programming is more stable.
If you like my post and it helped you please press THANKS.
Ok all works ok thanks
