I don't know if all of You experience the same thing.
But with the new loader for v 17.8 it is just shit.
I have lambda error on airbag and stuf like that.
today I finally flashed the above interface with Kolimer's V2 dumps (HW type 0x44). With latest \/(DS (17.8) it's crap... It shows as registered and activated, it was able to do the autoscan but... If I go to Instruments cluster Adaptation function, I get crap there... E.g. I select Staging and there's some kind of mileage (instead of values Active/Inactive). I tried a few more adaptation channels but it clearly displays wrong values in there!
Is 17.8 not compatible with the dumps? Which version should I use?
* MK100;
radsky (29th October, 2017)
Sure, here you go mate:
KL transceivers are made with cheap transistors. Good is case only.
Oddly, there are no prints "Versace".
Customers of this item will be welcome on the RT forum
Hi guys,
Just joined as I have an issue with VCDS. I did have a working copy of VAG12.1 installed some time ago but it appears my anitvirus wiped the crack so it was rendered useless adn the original install CD was toast due to being snapped in my case! Although if anyone has a copy of the older 12.1 with crack I'd be happy to roll back and use the older version.
I have installed the 17.8 software and crack on my Lenovo Thinkpad X201 running Win7 64 which worked last time when VAGCOM12.1 was installed and for some reason when I connect to the cable via USB (standard RT driver installed) it sees the interface as an RT interface then when I plug it in to the OBD the green LED comes on but it then fails to recognise the port.
If anyone has any info, please send me a PM with suggestions.
By the way I don't think the OBD port on the Transporter is an issue as I can connect with my ELM327 and Torque Lite on the T5 and the TT.
New VCDS Beta 17.10.0 (EN) was released. It's working with Loader_V2 and it seems that the problem with occasional Unregistered/Not Activated after long coding was fixed.
This cable is the one to go for ?
http://www.obd2cartool.com/atmega162...t-skoda-p-1404
and this one the chinese are running code to allow all languages...
http://www.obd2cartool.com/vagcom-17...anguage-p-1263
which one of these 2 works out best?
Did read through the threads but saw the second cable and got abit confused
Thanks in advance
what about strange values in Adaptation channels?
See my post here: http://www.digital-kaos.co.uk/forums...=1#post3126190
It seems that more people reported the same issue...
Would be really nice to have a clue if it's our cables fault, or it's the dumps issue...
Thanks and thumbs up for good work.
* MK100;
radsky (2nd November, 2017)
BGA Service
@radsky: is about 17.8.0 or about 17.10.0 beta?
liviudiaconu (3rd November, 2017)
This with autoupdate :
http://www.obd2cartool.com/index.php...oducts_id=1263
Gesendet mit Tapatalk
Hi All
I've updated my RL cable via USB (I was lucky - my cable had a proper loader)
VCDS 17.8. and polish version 17.1.3 + Loader_V2, interface works ok.
But with 17.10.0 beta after the test of the interface there is info "CAN not ready" -
It is necessary to make procedure of reflashing the interface again using VCDS 17.10 beta (via USB)?
Same here. Rhetorical question - is it only us (radsky and me) who are unlucky to have that issue? Guys, how about the rest? Could someone confirm that their interface is showing correct values in Adaptation? Or could shout that it's wrong too? Any input would be appreciated.
* MK100;
Bro thanks for uploading this package...
I read the info.pdf many times but i didnt understand that... HWtype shows me FW.1.96 / HW 0x46 / identif. Hex OEM... after i start EEPROM-> 0xFA24 -> Write -> Error ( Ft_SetBaudRate - Invalid baud rate / FT Write - General IO error / Usb Device error. After i try again i get this message (Not in Bootloader mode)
So i stop befor i make it worse.... is there a step by step instruction?
I would be very grateful if someone would help me!
